Corner Weights
Old Jul 14, 2007 | 05:09 PM
BrandonAGr's Avatar
BrandonAGr
Default Corner Weights
I borrowed some car scales and this is what my car ended up weighing:
LF 821 RF 867
LR 818 RR 796
51.1/48.8 front/back distribution
3302lbs, absolutely full tank of gas, amp and wiring but I removed the sub box before weighing, everything else stock. 98 Coupe
Do these numbers look similar to what other people have for stock c5s?
Old Jul 14, 2007 | 05:25 PM
AU N EGL's Avatar
AU N EGL
It is not "corner weights" it is "corner WEIGHTING"
Getting cross corner wts is to be as equal as possible is the goal.
that is with you ( or your wieght in the drivers seat ) too.
SO
RF+ LR = 49%
and LF + RR = 51%
that is WITHOUT YOUR weight. Find something that =s your wt ( I use old brake rotors) and put that in the drivers seat and then take some readings and make adjustments.
Old Jul 16, 2007 | 03:42 PM
JonLT4CE's Avatar
JonLT4CE
LF 821 RF 867
LR 818 RR 796
That sounds about right. I have a 98 coupe but I weighted mine with me in it. I think it was about 3480 and I'm 185. The 51/49 sounds right too.
Is your ABS unit in the rear? Mine is. I'm not sure when they switched.
Old Jul 17, 2007 | 01:10 AM
nitrojunky's Avatar
nitrojunky
I was 3395 with my 165# sitting in the driver's seat and a full tank of gas (3230 w/o me). 51/49 distribution. I'm mostly stock, but do have the longtubes + x + ti and OEM speedlines & no EMTs so I'm a few pounds lighter than normal.
To Corner Weights
