Sewing machine sound unacceptable .
Old Jul 28, 2007 | 12:36 AM
SLPRC5's Avatar
SLPRC5
Originally Posted by eurospec1
Not necessarily true, im running the MS3 with LS7 lifters, stock rockers and 7.40 hardened pushrods and i have 0 sewing machine noise, if they are properly torqued to GM's sequence i have never had any noise problems.
Do you have a sound chip???
Old Jul 28, 2007 | 11:02 AM
bayarea's Avatar
bayarea
ive ran 3 cams a 234/242 114, 242/248 110 and now im running a 257/266 .643/.622 110 with these cams ive heard the sewing machine noise with all of these cams but i dont sit there and cry about it. if you want it to sound stock keep it stock!
Old Jul 28, 2007 | 12:03 PM
WKMCD's Avatar
WKMCD
Originally Posted by SleeperC5
EG..I am running the Comp 7.425 push rods..Harland 1.7 roller rockers, Cadilla Race Lifter..guess I have to get the P2V measure and learn how to operate it...
Thanks,
Sleeper
I think if yor preload is good, that's about as good as you're going to get. You may have to learn to live with it.
Turn up the radio...
Old Jul 28, 2007 | 12:25 PM
voda1's Avatar
voda1
Seems like a lot of posters are running a muffler louder than a Z06, your engine sounds are drowned out. GM went from the stock LS1 cam to the Z06 cam without significant noise increase. Looking for 08 LS3 power level with heads, cam, headers, near 'stealth' as possible. Don't want a streetable race/'funny' car.
Old Jul 28, 2007 | 01:13 PM
pdd000's Avatar
pdd000
i had the sewing machine noise with the stock lifters. i put in caddy lifters and no more noise
Old Jul 28, 2007 | 10:36 PM
SLPRC5's Avatar
SLPRC5
What size cam do you have??
Old Jul 28, 2007 | 10:41 PM
SLPRC5's Avatar
SLPRC5
That's some big azz cams compared to what I'm running. I got caught up in the cure for the sewing machine noise by replacing the lifters, push rods and rockers and NONE of this quieten the sound by much...BTW..love the power...don't hear squat in the car cruising..only when along side something or inside the garage at home.
Not crying about it, just wondering why folks say they have the cure and it turns out to be
Old Jul 29, 2007 | 12:41 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
I feel sorry for the folks that blindly follow "definitive" advice "if you swap the lifters your problem will go away" posts; that's a lot of work and dollars for little to zero improvement 99% of the time.
Old Jul 29, 2007 | 01:09 AM
SLPRC5's Avatar
SLPRC5
Now I know and I hope this helps others..
Old Jul 29, 2007 | 01:38 AM
bayarea's Avatar
bayarea
ive never even cared about the sewing machine sound. i just always thought thats the way our engine sounded when it made more power.
Old Jul 29, 2007 | 01:45 AM
SLPRC5's Avatar
SLPRC5
Yep it is..when you mess with the cam
Just have to get use to it..
Old Aug 13, 2007 | 12:07 PM
SLPRC5's Avatar
SLPRC5
guess you one of the lucky ones...
Old Aug 18, 2007 | 03:23 AM
  #33
SLPRC5's Avatar
SLPRC5
Originally Posted by WKMCD
I run the Cadillac Racing lifters with .110 wall Trend pushrods, Comp 921 springs and a 234-240 112 XE-R cam and I have no valve train noise at all.
My $.02
Do you have a sound clip?
