Is there any quick and easy way to test a fuel injector? I'm thinking one mybe clogged because i've slowly started getting multiple misfires on cylinder #5 only. It started with a few hundred misfires (within a few minutes) a couple of days ago but has now increased to over 2000 misfires (within a few minutes) today. The MIL light is on and the only code i get is P0300.
I've checked and replaced all plugs and wires, cleared all codes and turned off MIL. But the P0300 code quickly came back and so did the MIL light...and i'm still getting over 2000 misfires. Any ideas?
Originally Posted by HP_Addict
Trying swapping the coil packs and see if the misfire moves with it. If no change swap the injector position as well. Cheap way to locate the problem.
You can also unfasten the fuel rail assembly and raise it up slightly just enough to get clean rags underneath each injector. Energize system and look for results.
HTH
Originally Posted by 97C5ENVY
I swapped the coils with no luck (problem stayed on Cyl #5). I haven't swapped injectors yet, but will do so tomorrow.
Before you do, try that tip I suggested. It might save you a little time maybe.
BTW, I can't take credit for it. It is a method (among others) suggested in the shop manual IIRC when diagnosing suspected fuel system problems. Using a NOID light is another, but that only shows that the suspect injector is triggering; not if it's actually passing fuel through it.
Sorry to bring back an old post, but my dads '98 is getting the same P0300 code and he's not exactly up on computerized cars. I'm going to try swapping the coil packs as mentioned above and see if that changes anything. He just got a fresh tank of Chevron 91 and added a full bottle of techron to it, he usually buys chevron, but it's the 86 and very rarely drives it (Like 10k miles in the past 8 years), so I'm leaning more towards a clogged injector than anything else.
C4's were notorious for injector problems, and using cleaners made it worse as it dissolved the insulation on the coil. A balance test will let you know which one it is, but you need a tool to fire the injectors individually. C4 is also batch fire.
Check for proper compression. You could also have a bad valve spring.
You can use a mechanics stethoscope and listen to each injector fire Electrically/Mechanically They will make a clicking noise when they fire. They should all sound the same if there operating correctly. You can use a dwell meter to see if there firing electrically
