PCV and catch can question
Old Sep 8, 2007 | 09:55 PM
tabbruzz's Avatar
tabbruzz
Default PCV and catch can question
Does the catch can adversly affect the PCV operation? The PCV is on for a reason so I am wondering if in the long run the catch can is doing more harm then good. Anybody test these tings to be sure?
Old Sep 8, 2007 | 10:08 PM
LoneStarFRC's Avatar
LoneStarFRC
A properly installed catch can is not eliminating the pcv system. Not sure what you're asking.
Old Sep 8, 2007 | 10:18 PM
tabbruzz's Avatar
tabbruzz
No, but is there any type of restriction by the introduction of the catch can??
Old Sep 8, 2007 | 10:21 PM
LoneStarFRC
Properly installed? No.
Old Sep 9, 2007 | 02:24 AM
DeeGee's Avatar
DeeGee
Not sure if you've taken a look at a catch can but it does just what its name implies.
When the system works as designed, oil is fed back into the intake and burns off but leaves residue. The catch can adds a couple of hoses and channels that oil into the can and deposits it safely out of the way.
If your question is does the engine/intake need that oil, the answer is a definite no.
Make sure you hook it up correctly though. We had a few tense days a while ago when one member fed water into his engine by hooking up the wrong hoses.
Old Sep 9, 2007 | 02:50 AM
dieseldave56's Avatar
dieseldave56
Default They met with little or no resistance.............
The catch can or tank or coalescing filter ( which I use) is simply put inline after the PVC valve that is routed back to the intake. I doubt that any backpressure or resistance added at all.
I personally don't have an excess oil issue with either my 2000 or 2001 C5s but added the oil catch can to remove any oil vapor ( as all engines have oil vapor to some degree). I don't need that building up on my intake, valves or pistons. Besides alot of factory cars , foreign and domestic have catch cans, particulary turbo cars.
As some have alluded to, not all catch cans are created equal that's for sure.
Old Sep 9, 2007 | 01:11 PM
tabbruzz's Avatar
tabbruzz
Thanks. I understand how the PCV works and the fact that the oil going into the intake is not the best thing. I also understand the reason why the catch cans are installed. I was more concerned with the actual crankcase ventilation and the possiblity that the catch can filters can be too restrictive for the PCV to actually work properly...I guess this may be the case for a filter that has been in the can for thousands of miles without replacement or cleaning...Any thoughts on this??
Old Sep 9, 2007 | 01:44 PM
cruisemon's Avatar
cruisemon
Use a catch can that does not have a filter element, but rather relies on the volume of the catch can to permit oil droplets to condense and collect.
To answer the original question, a non-filter catch can introduces a modest additional pressure drop (delta p or dp) by virtue of the fact that the vacuum line is longer and there is a slight dp across the fittings on the can. However, flow rates are low enough that the additional dp is inconsequential.
A catch can with a filter element introduces greater dp and as the oil collects on the filter element the dp increases. I don't know how much dp the system can tolerate before it affects performance or sets a code. Maybe someone else reading this might know.
Charlie
Old Sep 9, 2007 | 02:13 PM
tabbruzz's Avatar
tabbruzz
It appears as though the popular catch cans for the C5 have some type of filter or mesh type stuff. I have to wonder about how much testing was done on these things. I have never seen anybody provide any type of testing other then the fact that oil collects in the can. Is this all the oil or is some oil still getting into the intake? Well I am glad you understood my original question as it seemed to be somewhat confusing....Thanks
Charlie
Old Sep 9, 2007 | 03:16 PM
cruisemon's Avatar
cruisemon
I've never seen any test data on catch cans. Most of the info is anecdotal reports from users. The relatively larger volume catch can that allows oil droplets to come out of the air stream and/or allow vapor to condense because of the cooler side walls has proven effective, with some users reporting rather substantial quantities of oil collected. There may indeed be residual carryover even with the can, but the amount will be negligible.
Charlie
Old Sep 9, 2007 | 07:16 PM
Dave68's Avatar
Dave68
I know one guy who has done a bit of testing.......
http://www.conceptualpolymer.com/PCV...oval%20101.pdf
Let me know if you have any questions after reading my article. The long story - short is that most catch cans' filter media is not sized (density-wise) correctly for the flow and pressure that is found in an LS1 or LS6 PCV setup. It's somewhat akin to using a 100 CFM filter for a 1.3 CFM system. Yes, it will catch some of the oil,but not very efficiently.
Old Sep 9, 2007 | 09:24 PM
tabbruzz's Avatar
tabbruzz
Well Dave I think you pretty much answered my question. Thanks very much...
Old Sep 10, 2007 | 03:34 AM
dieseldave56
Default Dave68 does it again...........
I was just going to post that link from my 'favorites' list that Dave68 addressed . Dave turned my on to it many months ago. Way to go Dave.
That article and Dave's experience led me to the design that I finally ended up with. Adding over sized fittings and plumbing hoses ( stock plumbibg being 5/16 ID) also reduced the chance of increased back pressure in PVC system.
Old Sep 10, 2007 | 10:13 AM
Dave68's Avatar
Dave68
Thanks, Dave. Good filtration without restriction is my motto! Realistically, I think there is some leeway; how much is too much is a whole "nuther" experiment.
To PCV and catch can question
