I Need Your Knowledge Please !
Old Sep 14, 2007 | 12:51 AM
SoCalTTZ06's Avatar
SoCalTTZ06
Default I Need Your Knowledge Please ! I HAVE A LEAK EXPLANATION INSIDE
RUN DOWN ON CAR ..
2002 Z06
68K MILES
SO I WAS DRIVING MY CAR AND I SHIFT HARD AND I FEEL A SLIP .. IM
THINKIN IT IS THE CLUTCH . SO I TURN MY A/C ON AND I FEEL A HOT
BREEZE . SO I POP THE HOOD LOOK UNDER AND SEE THE AC BELT IS
OFF AND THE ACCESSORY BELT HAS WALKED IN TOWARD THE
MOTOR I SEE THE BELTS HAVE SOME OIL ON THEM AFTER
PUSHING THE CAR BACK I SEE ITS MOTOR OIL .I DONT THINK MY
CRANK IS NOT WALKING BECAUSE I CHECKED IT WITH A PRYBAR TO
SEE MOVEMENT AND THERE WASNT ANY.IT JUST LOOKS LIKE THE
CRANK PULLEY ISNT LINING UP WITH THE TENSIONER.SO I THINK MY
CRANK PULLEY HAS A LEAK OR A BAD PULLEY AND SEAL. CAN YOU
GUYS PLEASE CHIME IN AND HELP ME TROUBLE SHOOT THIS.
THANK YOU VERY MUCH IN ADVANCE
Old Sep 14, 2007 | 01:36 AM
SoCalTTZ06's Avatar
SoCalTTZ06
bump
Old Sep 14, 2007 | 03:01 AM
nitrojunky's Avatar
nitrojunky
What color is the oil? When my compressor died, it spit oil all over my engine bay. I thought it was engine oil until I relized it had absolutely no black in it; it was the a/c oil. Had to replace the compressor + accumulator + oriface tube.
Could also be something to do with the harmonic balancer pulley, but that's for someone else to answer.
Old Sep 14, 2007 | 11:54 AM
SoCalTTZ06's Avatar
SoCalTTZ06
Default i think its the harmonic balancer pulley
Hopefully it will be figured out soon
Old Sep 14, 2007 | 11:57 AM
vettenuts's Avatar
vettenuts
Just by symptoms and mileage, I would say the harmonic damper on the crankshaft.
Old Sep 14, 2007 | 01:05 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your damper is MOST LIKELY walking forward and your crank bolt is most likely also loose! Better get this checked out SOON before it damages a LOT of other stuff! The damper is a press fit (at least is suppose to be) on the crank snout so the crow bar test method may NOT provide you the info that you need to see if theres a problem!!
How much clearance is there from the front of the timing chain cover to the backside lip on the pulley!?!
Measure that and post the measurement!
BC
To I Need Your Knowledge Please !
