I Need Help.... ?? Blew a Piston Ring
Old Apr 11, 2008 | 08:12 PM
  #41
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Yeah, I ended up taking to a local machine shop right at 5pm today. It all worked out well so far.
Old Apr 11, 2008 | 08:16 PM
  #42
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Good to hear.
Lots of guys blowing up motors lately around here.
Old Apr 16, 2008 | 03:54 PM
  #43
Rob's 73's Avatar
Rob's 73
BQuicksilver,
Were you able to pull the piston with the engine in the car? Are you just replacing the one piston? I may be replacing some of mine.
Old Apr 16, 2008 | 11:28 PM
  #44
BQuicksilver
Originally Posted by Rob's 73
BQuicksilver,
Yes, and it worked out. I just started it yesterday. #7 made 194 compression before starting it and I haven't checked it after 3 heat cycles. Either way it's now my strongest cylinder. I think my ring land was broken for quite some time and got worse as I drove it hard. I was chasing tunes for over a year and after seeing how good the idle is now I bet that was my problem. I just used a 3 stone hone and checked all my ring gaps before re-install. #7 is a bit tough to hone b/c the cowl doesn't let you have a straight shot at things. Dropping in the piston was a bit trickier than expected since I was VERY careful not to scuff anything.
I also installed an LS2 tensioner, water pump, and oil pan while I was in there.
Doing it this way saved me pulling the radiator out and torque tube off. The cradle still comes off to get the oil pan off, so its still a major project either way.
Feel free to ask if you have questions. It can be done, but about the only big step it saves vs a full pull is removing the radiator since a lot of the front drive items needed to come off with the driver side head.
Old Apr 16, 2008 | 11:54 PM
  #45
ZeeOSix's Avatar
ZeeOSix
Originally Posted by Corvette-Chris
Can it definantly see a blown ring ?
No, a boroscope can not directly see the rings since they are below the top of the piston. If a broken ring caused a score in the cylinder wall you could see that though.
Old Apr 17, 2008 | 10:10 AM
  #46
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Did you have any problems re-installing the connecting rod after removing it.
The reason that I ask is that I am thinking of upgrading my rod bolts on a 99 FRC with the Kateck units, but am afraid that once I release the torque the caps may distort and I'll end up having to pull the motor to get all of the journals resized.
Anybody ever do this ? It's a 99 FRC with about 40K on the clock.
Old Apr 17, 2008 | 11:22 AM
  #47
BQuicksilver
I can't say I mic'ed the caps out or anything like that. I just released them a little on each bolt at a time and made sure evrything was properly lubed on re-install. The sleeves on the rod bolts were really tough to get out of the cap, but I don't think your 99 has these.
Old Apr 17, 2008 | 12:16 PM
  #48
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Thanks.
Old Apr 17, 2008 | 01:50 PM
  #49
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Old Apr 19, 2008 | 07:46 AM
  #50
BQuicksilver
Thanks Randy, I can't say just how much help you were throughout this whole ordeal.
Off to play with the car today at Grissom!!
