Ground location?
Old Nov 6, 2007 | 04:55 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Default Ground location?
Anyone know where the ground location is for the Left Actuator in the HVAC system? I'm getting codes B0361H, and B0363H. First one is LEFT ACTUATOR FEEDBACK SHORT TO GROUND, and the second one is LEFT ACTUATOR FEEDBACK OPEN.
Just started having problems after replacing my battery yesterday. Before that, everything was fine. Now the HVAC doesn't work correctly. Cold air blows out from the drivers side, warm air from the passengers. The fan doesn't respond to commands from the control unit. It blows at the same speed constantly. It will switch where the air comes out correctly, face, feet, or defrost.(After I repaired the vacuum hose I broke replacing the battery)
Any help is greatly appreciated, thanks gang!
Old Nov 6, 2007 | 05:47 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Here are the Connector pin outs, if that is what you are looking for.
Connector Part Information
12045470
32 Way F Micro-Pack 100 Series (NAT)
Pin
Wire Color
Circuit No.
Function
C1
BLK
150
Ground
C2
LT BLU/BLK
590
Sunload Temp Sensor Signal
C3
DK BLU
1646
RH Electric Actuator Position Sensor Signal
C4
Not Used
C5
BRN
41
Ignition Fused Feed (on)
C6
WHT/BLK
1236
RH Electric Actuator Motor Control
C7
DK BLU
1199
LH Electric Actuator Motor Control
C8
LT BLU
733
LH Electric Actuator Position Sensor Signal
C9
Not Used
C10
YEL
1791
Electric Actuator Position Sensor Feed (5V)
C11
TAN
63
Blower Speed Control Signal
C12
ORN
540
Battery Fused Feed
C13-C15
Not Used
C16
YEL
390
Instrument Panel Lamp Feed
D1
GRY/BLK
1798
Sensor Return
D2
DK GRN
734
Inside Air Temp Sensor Signal
D3
LT GRN/BLK
735
Outside Ambient Air Temp Signal
D4-D7
Not Used
D8
DK GRN
1394
Air Inlet Solenoid Control
D9
LT GRN
66
Mode Closed Solenoid Control
D10
PPL
1397
Heater Solenoid Control
D11
LT GRN
1395
Defroster Solenoid Control
D12
WHT
1038
Serial Data
D13
PNK
1396
Mode Open Solenoid Control
D14-D16
Not Used
Old Nov 6, 2007 | 09:23 PM
sneakelman's Avatar
sneakelman
12045470
Pin
Wire Color
Circuit No.
Function
C1
BLK
150
Ground
C2
LT BLU/BLK
590
C3
DK BLU
1646
C4
Not Used
C5
BRN
41
C6
WHT/BLK
1236
C7
DK BLU
1199
C8
LT BLU
733
C9
Not Used
C10
YEL
1791
C11
TAN
63
C12
ORN
540
Battery Fused Feed
C13-C15
Not Used
C16
YEL
390
D1
GRY/BLK
1798
Sensor Return
D2
DK GRN
734
D3
LT GRN/BLK
735
D4-D7
Not Used
D8
DK GRN
1394
D9
LT GRN
66
D10
PPL
1397
D11
LT GRN
1395
D12
WHT
1038
Serial Data
D13
PNK
1396
D14-D16
Not Used
Thanks Screw. Now that I know the color wire, I just need to find the location of said wire. Anyone know?
Old Nov 6, 2007 | 10:44 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Why dont you try this? Clear the DTCs and see if it will work normaly again.
Here is the website to help you explain the DTC codes:
These are the absolute best C5 Diagnostic Trouble Code (DTC) web sites!!!
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.\
Here is another very good site:
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Write down and post your DTC’s Then clear them ALL!
BC
Old Nov 7, 2007 | 08:45 AM
sneakelman's Avatar
sneakelman
BC
Thanks Bill, but I already tried that a couple times. Each time I clear the codes, no codes prompted in the DIC. Then I exit the codes mode, re-start the car, get the same thing from the HVAC, turn the car off, check the codes again and the same two are there.
There has to be something wrong with that particular circuit. It say short to ground and also open to ground. I really need to find where this circuit grounds at so I can check that area for corrosion. I read your post about cleaning all the grounds(great information BTW) but still don't know where this one grounds at. I haven't got the time right now to clean each and every ground connection on the car. Using it for my DD at the moment(son needs my other car) and it gets pretty darn cold over the winter.
Any more assistance is greatly appreciated!
Old Nov 7, 2007 | 05:57 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Im looking at the HVAC shhematic and here are ALL of the HVAC accociated grounds and what they are associated with and where they are at:
HVAC control head Connector D,,Pin 1
HVAC Fan Motor = G-202 Passengers foot well
AC Compressor Clutch= G-101 Eng Compt fender behind headlight module
According to the service manual, if you get B0361 Connector C, pin 8 of the HVAC PROGRAMMER MODULE (control head) and or pin 9 of the LEFT ACUTATOR is shorted.
According to the service manual, if you get B0363 Connector C, pin 8 of the HVAC PROGRAMMER MODULE (control head) and or pin 9 of the LEFT ACUTATOR is open.
I would remove the HVAC control module (Below the radio) and examine the wires and connectors, with the module out and disconnected, check the connectors, wires and harness going up to the left actuator.
Here is what the actuators look like on the drivers side:
Here is what the actuators look like on the passengers side:
Hope this helps.
BC
To Ground location?
