Please help!
Old Nov 10, 2007 | 10:58 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by BlackZ06
I would NEVER contradict Bill Curlee or Bill Dearborn .... ANYTHING they post is "take it to the bank" golden good stuff ....
Heck, I suspect Bill Curlee has at one time disassembled his C5 down to the last nut and bolt as I have seen him post pictures of parts you wouldn't even know are on the car .....
Stephen
I respect you C5 knowledge also! You have posted lots of good stuff.
You know, sometimes,, its NOT what you know but just how you go about saying it. There are forum members that know a LOT more than I do. I try to be fair with everyone and seldom slam or attack people.
I frequently give people my phone numbers and have even invited them over or even go to their house to help them fix their Corvettes. I'm not limited to C5's.
I take lots of pictures of my car and lots of pictures of cars that I have worked on and I have used some other members pictures (with permission) and I take lots of pictures of parts at Carslile. When you provide someone with a picture of the problem or a component, it really helps. Sometimes people just cant find those damn pesky ground points!
Thanks for the back up!
BC
Old Nov 10, 2007 | 11:09 PM
TraceZ's Avatar
TraceZ
Originally Posted by Bill Curlee
Yep,,,1214 is the EBTCM kiss of death. It indicates that the internal power relay is bad. Send it out for repair. Its a simple task to remove the module. 6 torx head screws and two connectors. Its even a plug and play module. NO programming necessary!
BC
Internal power relay, huh. That doesn't sound too bad. Is the relay available somewhere? Is it easy to replace? Many guys on this forum have basic electronic skills and can solder a new relay on a printed circuit board. Is there a how-to?
Old Nov 11, 2007 | 12:22 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just about Everything is repairable. It all depends on how much experience you have and, time and money you want to spend or don't want to spend if your willing to break it down and repair it your self. There have been a dozen or so people on the forum that have ripped modules and components apart and figured out work around and repairs. There are post on repairs to the Door Control Modules, Instrument Panel Cluster, HVAC Control Panel, Wheel Speed Sensors, Tire Pressure Sensors and there are probably a few more.
I have personally ripped the EBTCM apart.
2001-2002 EBTCM
As you can see, the module is potted in RTV and yep,,,it was a royal BITCH to separate the case from the module.
ABS fixer has researched this module and has perfected it's repair. He installs better relays and gives it a WARRANTY! There are certain EBTCM's that have issues that not even he can fix! The module contains a micro processor and I believe that if that it has an issue, "stick a fork in it,,it DONE!"
My module; once disassembled and closely examined, it had numerous cold solder joints. An 8 year old could have done a better job!
I took the module to work and using a microscope repaired all the crappy solder joints. I have not tried to reinstall it into the car to see if that was the issue. (Too busy driving it and having a BLAST! )
DELPHI uses **** poor relays and poor soldering techniques! GM needs to re-evaluate Delphi's quality control.
Hell, give it a try, what have you got to loose?
BC
Old Nov 11, 2007 | 12:24 AM
Frankiexx's Avatar
Frankiexx
Wow, didn`t mean to start a war. Think I`ll send it out. Even if the problem is a ground or something, the module is going to go sooner or later. Might as well do it while I have the cash. Think I`m gonna send the climate control unit as well. $200 to fix both...can`t hardly go wrong. Thanks for the info. Now to find the instructions to remove both tumors!!
Old Nov 11, 2007 | 12:31 AM
Frankiexx's Avatar
Frankiexx
If I keep driving it til I get a chance to fix it, is there a way to stop the display from flashing the "service abs" message?
Old Nov 11, 2007 | 12:39 AM
BlackZ06's Avatar
BlackZ06
Push the RESET key on the DIC control panel.
Old Nov 11, 2007 | 12:47 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Frankie
I just noticed your from Baltimore. I was born and raised there. I lived in Dundalk. Went to Dundalk High. What part of Balto do you live in??
Until you get the module fixed, you stuck with the DTCs and DIC messages. Sorry, If you clear the messages bu pushing the RESET BUTTON, it will go away until you do the next ignition cycle. If you want to check the Grounds, look at G-101 and G-104/108
G-101 is aft of the drivers side headlight:
G-104/108 is next to the battery:
ALL Grounds:
Hope this helps and never be afraid to ask for help!
BC
Old Nov 11, 2007 | 12:49 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Steven! What are you doing up so late?? I agree Reset button will get rid of the messages. I posting minutes behind you.
BC
Old Nov 11, 2007 | 12:55 AM
Frankiexx's Avatar
Frankiexx
Bill, small world. I live in Sparrows Point. My wife and her sister graduated from Dundalk. I just started talking to the guy who runs the corvette performance center on Philadelphia rd. Gonna have him check out my non functioning washer pump as well
Old Nov 11, 2007 | 01:24 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ah,,spent lots of time in Sparrows Point. Father owned a boat and we had it docked down there at Rudy's Marina. My dad and mom also worked at the steel mill for 35 years!
As for your washer pump, first check the instrument panel fuse center, Fuse # 10 (WSW) 25 amp. Most likely it is good if your wipers work. If it's just the pump, the button on the end of the stalk could be bad or the motor it self could be bad. Just remove the washer pump from the tank and either ohm it out or just attach 12 VDC to it to see if it runs.
Check the connector that plugs into the motor and the washer motor.
Oh by the way, the ground for that circuit is located at G-101 & G-201.
Hey,,,,G-101 is also associated with the EBTCM. LUCKY might be on to something!!!
BC
BC
Old Nov 11, 2007 | 01:46 AM
Frankiexx's Avatar
Frankiexx
Maybe a little luck for me. My grand father, father and father in law all worked there for a long time. That whole area by Rudys (lynhurst) is all houses now and Rudy`s was sold a few years ago. Haven`t been there since it changed hands. I`ll check out those grounds tomorrow.
Old Nov 11, 2007 | 12:35 PM
lucky131969's Avatar
lucky131969
I hate when someone with 300 post goes on an attack. This is the SECOND post that you have had issues with how I interface with someone. If you don't like what I have to say, just add what you have to say.
I've been a member of this forum since 1999 and have over 8000 post. If you want to talk this guy through the entire EBTCM troubleshooting procedure, be my guest. Then you can tell him the send his EBTCM out for repair. The relays inside the module are junk! Sending it to ABS fixer resolves this issue.
There are HUNDREDS of EBTCM post on the forum archive. Give the search thing a try. It works very well. Probably 3/4 of them are 1214 issues. Im quite sure that I have typed out the entire EBTCM troubleshooting procedure at least ONCE.
If you really want to help the OP, tell him that not only does he loose TRACTION CONTROL but most importantly anti-lock braking and Active Handling.
BC
Interesting. So the number of posts one has on the forum somehow elevates them to "God like" status. I'll have to remember that. Like I said, while it very well may be the EBTCM, there is a procedure to be absolutely sure. I'm not into "shotgunning parts", even if they are common failures. That train of thought works just fine if you have another part lying around, but if you don't and your dealing with someone else money/time/car, than I think it's better to take them through the steps. Moreover, if the OP goes through the entire procedure, and finds out its the EBTCM, then he has learned how to troubleshoot the system, and can help other members in the future.
Perhaps it's just because I have worked in an industry that is not tolerant of just changing parts. If I sent out a part for repair, having not troubleshoot the system to said component, and the got it back from repair finding that it did not fix the problem, I would be in a pickle. Now, I have to re-troubleshoot the system, costing the company more time(not to mention the cost of sending a good part for repair) and do what I should have done in the first place. I just don't see how another hour of time is worth not being sure.
Sorry I stepped on your toes Bill, but I'd rather be thorough than make a mistake any day of the week.
Old Nov 11, 2007 | 01:00 PM
  #33
Frankiexx's Avatar
Frankiexx
Well, unfortunately I don`t own a shop manual yet, so I don`t know the troubleshooting proceedure. Is it posted on here. Hey, I`ll give it a shot. Whats the worse that can happen, I`ll learn something! Thanks for all the tips. Being new to the corvette world, I feel kinda stupid asking some of these questions. Thanks for taking the time to help.
Old Nov 11, 2007 | 01:29 PM
  #34
lucky131969
There are no stupid questions. Keep asking, and keep learning. Get a service manual when you get a chance. In the interim, there is a wealth of info on this forum to guide you.
Old Nov 11, 2007 | 02:56 PM
  #35
Frankiexx's Avatar
Frankiexx
Well, just took G101 apart. everything was very clean. Cleaned it anyway to be sure, and still same problem.
Old Nov 11, 2007 | 03:19 PM
  #36
royski's Avatar
royski
Default question bill ,s
i second that
Old Nov 11, 2007 | 03:54 PM
  #37
lucky131969
Originally Posted by royski
i second that
Hmmmm. So, you would rather just have someone tell you to change a part on your car, than cover all the bases to make sure it's bad. Ok, well..... I guess to each his own. I just like knowning what's in the kool aid before I drink it.
To Please help!
Old Nov 12, 2007 | 01:15 AM
  #38
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Lucky131969,
Don’t even think about going up against Bill. He knows what he is talking about and has helped more people on the forum with electrical problems then you can imagine. Besides, he also builds atomic bombs.
Clayton from Las Vegas
Old Nov 12, 2007 | 02:08 PM
  #39
LBZ51girl's Avatar
LBZ51girl
CI 6-7-8-9 Veteran
St. Jude Donor '08
Yes, you are right I just feel sorry for the poor bas--rd that owns that black 1998 now, hope everything was put back in the right place
the evidence
Old Nov 12, 2007 | 03:00 PM
  #40
lucky131969
Originally Posted by LV Vette
Lucky131969,
I will certainly keep that in mind LV Vette. I had know idea I was guiding the OP down the wrong path......until now. I feel......so........ashamed.
