Best T56 fluid?
Old Nov 14, 2007 | 04:05 PM
imflyinbiya's Avatar
imflyinbiya
What about an 03?
Old Nov 14, 2007 | 11:53 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
O.k., this is bugging me, like a lot of Internet "facts".. Just because something is repeated a 1,000 times doesn't make it true.
I'm at approx. 25K miles with Red Line MTL; my poor, helpless paper blocking rings seem to be holding up beautifully, shifts as good as a T56 with linkage can shift.
Until someone definitively proves that RL MTL is harmful to older transmissions, I'll continue to be blissfully ignorant.
Old Nov 15, 2007 | 01:37 AM
Synergy Motorsports's Avatar
0Synergy Motorsports
Former Vendor
I am glad you said this. Not all that is said is what it is. We cant tell what fluid is the best out there. I know that even though i stopped using mtl i had friends who used it with zero issues. Some tranny guys say yes and some say no. Which is the better? I dont think we can tell. I say use what works for you. I know what works for us.
Rick
Old Nov 15, 2007 | 04:28 AM
01 stock c5's Avatar
01 stock c5
I just had my tranny rebuilt and the shop put Mobil 1 Synthetic no complaines yet.
originally posted by another member....
AMSOIL "White Paper" Gear Lube Study - GM, Royal Purple Redline, AMSOIL
For those interested in a comprehensive comparison of the major gear lubes on the market, AMSOIL just released this today. While this was a study commissioned by AMSOIL, it is still a very interesting read.
Gear lubes tested:
Synthetics:
AMSOIL Severe Gear 75W-90
Castrol SYNTEC 75W-90
GM Synthetic Axle 75W-90
Lucas 75/90 Synthetic
Mobil 1 Synthetic 75W-90
Mopar Synthetic 75W-90 with Mopar LS additive
Pennzoil Synthetic 75W-90
Red Line Synthetic 75W-90
Royal Purple Max-Gear 75W-90
Torco SGO Synthetic 75W-90 with Torco Type G LS additive
Valvoline SynPower 75W-90
Petroleum Candidates
Castrol Hypoy C 80W-90
Pennzoil Gearplus 80W-90
Valvoline High Performance 80W-90
AMSOIL Gear Lube “White Paper” (481 KB pdf file)
Old Nov 15, 2007 | 06:09 AM
vettenuts's Avatar
vettenuts
I believe Phil at DTE recommends this fluid as well. The only downside I am aware of (or have been told) is harder shifting when cold. Not sure on the blockers. That said, mine doesn't exactly shift like butter cold with the Amsoil either so it may just be characteristic of the tranny itself. Knowing this, I am pretty careful shifting this time of year now the the temp has dropped until things warm up.
Old Nov 15, 2007 | 05:57 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I think a lot of posts need some clarification.
Are folks running a totally OE tranny or an upgraded tranny???
It's one thing to know what fluid is best for an OE tranny with the paper blocker rings. But, there are a lot of folks that have rebuilt or upgraded the tranny and probably had the paper rings removed so they can run fine on a totally different fluid.
We've got to remember to compare apples to apples especially when your talking about "what's the best fluid"
Old Nov 18, 2007 | 07:45 PM
Dan_the_C5_Man
Exactly.. Yes, a bit stiff for the first few miles but after that; beautiful.. I was hoping you'd jump on the RL MTL bandwagon with me..
Did you see that thread over in LS1Tech talking about how roller-tipped rockers really don't roll over the valve tip, another reason stock rockers are superior? An interesting argument and I can see how it would be possible that at high RPM's + high loads that the roller might slide vs. roll over the tip.. Always something..
