Best T56 fluid?
Old Nov 13, 2007 | 11:29 AM
LsJuan25's Avatar
LsJuan25
Default Best T56 fluid?
What is the best Transmission fluid I can put in my T56?
Old Nov 13, 2007 | 11:50 AM
vettenuts's Avatar
vettenuts
I think you will likely get multiple answers on what's best, I am using Amsoil and it has been shifting fine with it so I don't plan to change anytime soon. Some are running the Redline MTL, I am unsure of how well that works. There is also the question of when the paper blocking rings were replaced and the impact of that change on what oil you can safely use.
Old Nov 13, 2007 | 11:55 AM
imflyinbiya's Avatar
imflyinbiya
I have an 03, and just want a good fluid to use for daily driving. After searching, I think I am even more confused.
Old Nov 13, 2007 | 03:34 PM
Oldvetter's Avatar
Oldvetter
Amsoil ATF or ATD works great. I personally now run Amsoil ATD. I previously ran Mobil 1 ATF, after 50,000 miles it was grinding when going into 6th gear, a change to Amsoil ATD stopped that. I am not necessarly blaming Mobil 1, these transmissions are sensitive to dirty oil, I think they need changed every 50,000 miles. And the service manual says you never have to change it !!!
Old Nov 13, 2007 | 03:42 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Dexron is fine for a DD
Old Nov 13, 2007 | 03:49 PM
LsJuan25's Avatar
LsJuan25
I want it to race the dogfight out of it!! Hehe
Old Nov 13, 2007 | 04:01 PM
MadMaxZ06's Avatar
MadMaxZ06
I use Redline D4 ATF and like it.
- Max
Old Nov 13, 2007 | 04:18 PM
FKING1's Avatar
FKING1
- Max
Me too.
Old Nov 13, 2007 | 07:54 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
- Max
Old Nov 13, 2007 | 08:28 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
..Some are running the Redline MTL..
Works great!
Old Nov 13, 2007 | 08:29 PM
2KFRC5's Avatar
2KFRC5
According to this: http://corvettemechanic.com/forum/sh...ghlight=dexron Dexron VI is not for the manual tranny.
Old Nov 13, 2007 | 08:55 PM
Sick Z06's Avatar
Sick Z06
AMSoil ATF+4 and doing fine.
Old Nov 13, 2007 | 08:57 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
Your transmission has paper blocker rings unless it has been rebuilt. This limits the brand of transmission fluids you can use. Search C5 tech for "paper blocker rings" for brands that will work.
Old Nov 13, 2007 | 10:57 PM
Mike94ZLT1's Avatar
Mike94ZLT1
I was under the impression that 01+ had carbon fiber rings?
Old Nov 14, 2007 | 01:05 AM
Synergy Motorsports's Avatar
0Synergy Motorsports
Former Vendor
I found that in some cases the Redline MTL can be too slick. The D4ATF is better in the long run. Another good fluid is GM's really expensive bottle of syncromesh fluid. They have two versions, the not so cheap version is pretty cool.
Rick
Old Nov 14, 2007 | 09:09 AM
Mike94ZLT1's Avatar
Mike94ZLT1
I always used Honda ATF Z-1 in my 6 speed F-bodies with great results, I've been kicking around the idea of putting it in my Vette. I think I will in the spring.
Old Nov 14, 2007 | 09:15 AM
Former Vendor
His profile shows that he has a 99.
To Best T56 fluid?
Old Nov 14, 2007 | 10:23 AM
Pumba's Avatar
Pumba
I just switched from Castrol SynTec LT to Royal Purple Syncromesh.
The Castrol Syntec LT worked fine once it was warmed up. With it I never had a high temperature warning during track days.
The Royal Purple Syncromesh shifts much easier cold.
I have the Carbon Fiber blocker rings.
Old Nov 14, 2007 | 01:05 PM
khadiyev's Avatar
khadiyev
my tranny was hard to shift, original fluid, i put in Amsoil and it feels like butter now, a lot smoother
Old Nov 14, 2007 | 03:55 PM
HollywoodFRC's Avatar
HollywoodFRC
Default Beware of Ruining the Paper (Celulose) Blockers
After extensive reading on this forum, it looks as if AMSoil Synthetic ATF is the way to go on a '99 MN6. As stated above, you can damage the internal blockers of the T56 by not using the right transmission fluid. I replaced the factory transmission oil with AMSOil Synthetic ATF 11,000 miles ago and have had absolutely no issues and nothing but smooth shifting despite the 'mickey mouse' factory shifter. Be safe, go with AMSOil Synthetic ATF.
