NEED HELP after head swap
Old Nov 24, 2007 | 01:49 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default NEED HELP after head swap
I just tried to start it up for the first time after the head swap and the temp guage is pegged out and the codes I got are P0118, P1636, P1638. It will not start unless it is floorboarded.
Old Nov 24, 2007 | 02:40 PM
vettenuts's Avatar
vettenuts
Did you get the ground back on the back of the driver's side head?
Old Nov 24, 2007 | 02:45 PM
Corvette-Chris
St. Jude Donor '08
Yes ^
Old Nov 24, 2007 | 04:27 PM
Corvette-Chris
St. Jude Donor '08
The coolant temp is reading 62*F but its so flooded that their is fuel in the oil.......Also, When I turn the key on the Fuel Pressure is about 60 PSI which is fine, but after a few seconds it drops to about 15 PSI. Could an injector be stuck open??
Old Nov 24, 2007 | 05:06 PM
vettenuts's Avatar
vettenuts
Either stuck open or commanded open. What exactly did you change, cam and heads only? Are all the electrical connectors back on?
Old Nov 24, 2007 | 05:09 PM
Corvette-Chris
St. Jude Donor '08
Just heads. The cam was already in. Everything is plugged back in. I have SVO 30# to put in but I know it wont run with those to long without a tune so I was just going to start it and make sure everything was fine before I went to have it tuned so the stock injectors are still in
Old Nov 25, 2007 | 09:00 AM
vettenuts's Avatar
vettenuts
Do you have any kind of check off list or something to go by as far as what was disconnected? Its likely something very simple.
Old Nov 25, 2007 | 10:55 AM
Corvette-Chris
St. Jude Donor '08
Yeah I used the LS1HowTo as a guide but didnt use it all that much. I have doubled checked everyhting. All the injectors are definantly plugged in but we may take the intake back off to check if I forgot anything in the back. I dont think I did but I guess it doesnt hurt to check.
Old Nov 25, 2007 | 11:02 AM
BonestockZ06's Avatar
BonestockZ06
Thats a good start.. Perhaps it can be an air leak from underneath the intake .. Check the map and vacuum from behind the intake and make sure theyre plugged in. Either way, thats where I would start.
Old Nov 25, 2007 | 11:13 AM
FRCTony's Avatar
FRCTony
First you said the temp gage was pegged, then you say 62F?
I have had cars flood and fuel foul plugs when started without coolant due to false temp reading.
Did you pull plugs? If you have a stuck injector, you should be able to tell which one.
Old Nov 25, 2007 | 12:15 PM
Corvette-Chris
St. Jude Donor '08
No, the guage is pegged out but the OBD II says the ECT reads 62*. Havent pulled the plugs yet
Old Nov 25, 2007 | 03:24 PM
Corvette-Chris
St. Jude Donor '08
Turns out there were 2 problems. I also have nitrous and either some wiring is backwards making the silonoid stay open or it is time for a silonoid rebuild because that was causing it to lose fuel pressure. The second problem was the ECT sensor. It would read 62* first, then when we went back out this morning to check again it read -38...BINGO!! I changed it and it runs great without the nitrous lines hooked up to the end of the fuel rail. When I hook up the Nitrous system fuel line, it wont even start and almost floods out immediatly. At least it runs though
Thank You for all those who offered advise
Old Nov 25, 2007 | 06:47 PM
vettenuts's Avatar
vettenuts
Glad you found it and its back running again. It can be frustrating after all that work to have a problem like that.
So did you install the AFR's, if so how do you like them? Which gasket did you go with?
Old Nov 25, 2007 | 06:58 PM
Corvette-Chris
St. Jude Donor '08
Yes I did put the AFRs on but went with the GM MLS gasket. I havent had it tuned or anything yet or even driven it, just heard it idle. Thaks for all your help and advise. It really helped alot
Old Nov 25, 2007 | 06:59 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Dont forget to change that oil!!! Glad you fixed it!
BC
Old Nov 25, 2007 | 08:26 PM
Corvette-Chris
St. Jude Donor '08
BC
Yeah I already drained the brand new oil because it was full of gas and refilled it with new. Now I just gota drive a little while and change it again. Thanks Bill I appreciate it
To NEED HELP after head swap
