what oil do you use?
Old Nov 26, 2007 | 11:17 AM
  #41
BubblePuppy's Avatar
BubblePuppy
From: Si Vis Pacem Habeatis Filios Vestros, Ad Bellum Parare Modo
Originally Posted by VetteTech81
AMSOIL! I use it in just about all my toys! Especially the trans fluid. But there are many good choices out there.. as long as it's a good brand name synthetic that meets the requirements, and you change it when needed, you should be fine.. oils have improved over the years..
-=Rick
Ditto...
Old Nov 26, 2007 | 01:14 PM
  #42
peebee_c5's Avatar
peebee_c5
Zaino Z5.
Old Nov 26, 2007 | 01:29 PM
  #43
uracowman's Avatar
uracowman
Mobil 1 10w30
Old Nov 26, 2007 | 03:39 PM
  #44
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Mobil 1 5W30 same as the factory fill
Old Nov 26, 2007 | 06:33 PM
  #45
MadTom's Avatar
MadTom
Exclusive Mobil 1 Super Syn 0W-40 on my Corvette and BMW
Old Nov 26, 2007 | 08:07 PM
  #46
vetter79's Avatar
vetter79
Royal Purple 5/30
Old Nov 26, 2007 | 08:20 PM
  #47
hattitude's Avatar
hattitude
Originally Posted by vetter79
Royal Purple 5/30
I love your Avatar..... wish I had the guts to use that answer in school......!!
Old Nov 27, 2007 | 03:29 AM
  #48
kendo347's Avatar
kendo347
Castrol Syntec European Blend otherwise known as German Castrol is my choice. If I had to pick another I would go Amsoil.
Old Nov 27, 2007 | 10:34 AM
  #49
silverbird's Avatar
silverbird
St. Jude Donor '08
Mobil 1 5W-30 Full Synthetic with Mobil 1 filter.
Don't use the "extended performance" version.
Good luck,
Silverbird
Old Nov 27, 2007 | 11:13 AM
  #50
AU N EGL's Avatar
AU N EGL
Good luck,
Silverbird
I used the extended performance stuff once. never again.
Old Nov 27, 2007 | 08:37 PM
  #51
70T/A400's Avatar
70T/A400
Default Oil in crankcase
I use Valvoline VR-1 10W30 conventional oil. It's high in ZDDP and has good detergents as well.
Old Nov 28, 2007 | 02:13 AM
  #52
2blklt4's Avatar
2blklt4
mobil 1 5w-30 every 3,000 miles...yes i said it 3,000 miles
Old Nov 28, 2007 | 03:01 AM
  #53
skydive120's Avatar
skydive120
Mobile 1 and filter-- have had no problems yet, just change it when required-- 3,000 miles or less.
Old Nov 28, 2007 | 09:26 PM
  #54
Goldfisher's Avatar
Goldfisher
Originally Posted by slowazzvette2
I use Nippon and a mobil one filter. It costs $10 bucks a quart though but you notice the difference
What difference do you notice? Mobil-1 10w30 here.
Old Nov 28, 2007 | 09:36 PM
  #55
VetteTech81's Avatar
VetteTech81
His wallet is lighter..
Old Nov 28, 2007 | 09:47 PM
  #56
Pro Street's Avatar
Pro Street
Mobil 1
Old Nov 28, 2007 | 10:27 PM
  #57
Mike94ZLT1's Avatar
Mike94ZLT1
You RP guys need to do a little research...
I put 5K miles on my stroker using Shell Rotella T 15w40 dino oil I just switched to Redline 10w40. Been using the Wix 51042 filter ever since I put this engine in.
To what oil do you use?
Old Nov 28, 2007 | 11:05 PM
  #58
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Walmart full synthetic 5w-30 with walmart brand oil filter. Oh yeah, can you say $15 for 5 quarts and filter! Nice
Cajun
Old Nov 28, 2007 | 11:55 PM
  #59
427435's Avatar
427435
You should be looking for an oil that meets the following:
1. 5w-30 viscosity. The "5w" part provides better start-up lubrication than a 10w-30 oil and the "30" part gives you the same lubrication at operating oil as a 10w-30 does.
2. Meets GM spec 4718M
3. Has the API logo on it.
I use Mobil 1----have used it for years in all kinds of engines and never an engine problem related to lubrication.
Old Nov 29, 2007 | 01:20 AM
  #60
justForYou111's Avatar
justForYou111
Cruising
Mobil 1 for me.
