Replacing lifters
Old Dec 8, 2007 | 12:52 PM
LDB C5's Avatar
LDB C5
Old Dec 12, 2007 | 03:57 PM
Bill Hilt's Avatar
Bill Hilt
How many hours will it take to replace the lifters in the ls6. Do i have to drain the water ?
Old Dec 12, 2007 | 04:31 PM
vettenuts's Avatar
vettenuts
Originally Posted by Fastbird93
Those Caddy lifters have been touted as almost a carbon copy of Morels by a couple of very reliable sources (engine builders).
Not even close in design or materials actually. Roller is different material, Morel is open design, internal tolerances are different, steel is different and bearings are different. Morels are also a lot taller.
Old Feb 27, 2008 | 08:16 AM
electra's Avatar
electra
I got 30K miles on the OEM LS6 lifters after G5x3 Cam. Installed the Morels and got 55K. My mechanic said the big cam was the culprit. Just installed the Cadillac Racing lifters. I hope for additional longevity.
Old Feb 27, 2008 | 08:32 AM
jedblanks's Avatar
jedblanks
What do you mean "got xxx miles" -- how did you know they failed?
Old Feb 27, 2008 | 08:41 AM
ArKay99's Avatar
ArKay99
I used the Comp 850's as a replacement for my oem's in my h/c setup. They were ok, but when all was said and done, I don't think they were any better than the oem's. One thing I did notice about them is they were noisey. I had valvetrain tick that was louder than my freinds almost identical setup that used oem lifters. His are still quiet. My cam was the one in my sig.
I am now using the Caddy lifters in my 403. I got them from SDPC. The current cam is a 242/242 .610"/.610" and they are quiet. So far, 70 miles on them and no problems.
Old Feb 27, 2008 | 12:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Old Aug 18, 2008 | 12:18 AM
bcarp's Avatar
bcarp
dont mind me just alot of info i will need later here
