Floor jack for the C5?
Old Nov 24, 2001 | 08:34 AM
Jim Shearer's Avatar
Jim Shearer
Default Floor jack for the C5?
I remember a while back that someone found a floor jack for the C5. I could not find anything in the archives. Does anyone know where to get one?
Old Nov 24, 2001 | 08:56 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Default Re: Floor jack for the C5? (Jim Shearer)
I got my 3 1/2 ton jack at Sears. Came with two jack stands and was $99.00+ tax. Now to get some pucks....
Old Nov 24, 2001 | 09:00 AM
WEF's 95's Avatar
WEF's 95
Default Re: Floor jack for the C5? (acepilot)
Where can you buy real pucks? The stores I've looked in only carry the street hocky type.
Old Nov 24, 2001 | 09:04 AM
Jim Shearer
AcePilot,
Will your jack fit under the C5 with pucks? What is the model number?
[Modified by Jim Shearer, 7:04 AM 11/24/2001]
Old Nov 24, 2001 | 09:07 AM
Grumpy's Avatar
Grumpy
MONARTOR
PArt number 950140 and I believe it will. Still in the box. Hehehe
Old Nov 24, 2001 | 09:11 AM
Grumpy's Avatar
Grumpy
MONARTOR
Default Re: Floor jack for the C5? (WEF's 95)
http://www.cau-llc.com/ (supporting vendor)
Old Nov 24, 2001 | 10:04 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Buy something decent. I have some Lincoln jack I got at costco for 119 whih were usually 300. I bought a small sears jack for the track and it's a POS! When you jack the car it's a million pumps and it feels lke it's going to collapse. I now just pick up the heavy jack and take it to the track it way less fustrating. Everyone uses it too. THis jack will last a life time. If yopu really want to get a aluminum one they are 700-900 and put you up in a few pumps.
Old Nov 24, 2001 | 10:11 AM
Shadow's Avatar
Shadow
I've owned a Lincoln for about four years and think it's a great tool.
I also heard about a line of products from AC Hydraulics ( http://www.shopquip.com/~workshopjacks.htm) that are very low profile.
Old Nov 24, 2001 | 11:57 AM
Jim 47's Avatar
Jim 47
Jim:
There was a GP a while back. I got a DK20 at that time. It is an excellent jack with a colapsed height of only 3 1/4 inch, and has a capacity of 4400 pounds.
Contact is Brian Lockhart at 800 229-6218 or 860 626-9633. It is an expensive jack but well worth the $199 plus shipping.
:yesnod:
Old Nov 25, 2001 | 09:47 PM
Dave68's Avatar
Dave68
Someone once mentioned that in order to use the average 19-inch capacity floor jack to lift up the front of a C5, you need to glue a couple of 3/4-inch thick wood boards together (for each front tire) and simply drive your car up onto them. That way, you'll have enough clearance to get the jack underneath.
I'm going to do this soon. As far as protecting my aluminum underbody, I'm going to turn-down a PVC disc so that it fits in the floor jack saddle. I will also machine four wooden "protectors" for my floor jacks.
Old Nov 26, 2001 | 07:38 AM
vettenuts's Avatar
vettenuts
Default Re: Floor jack for the C5? (Dave68)
I have the Sears floor jack and it doesn't fit at all. What did fit was a scissors jack. I used it with a 5 lb weight I bought at Wal Mart. I glued a sheet of rubber to the top of the weight to protect the car. The rubber was cut from an old inner tube.
Bottom line, the scissors jack worked great, so I may upgrade to a better one. The one I have came from a yard sale and doesn't move too freely even though I greased it.
Old Nov 26, 2001 | 09:04 AM
Busted Knuckle's Avatar
Busted Knuckle
If you really want the perfect jack (my opinion) for the C5 and also a jack for "LIFE" go to this place http://www.griotsgarage.com/catalog.jsp?&SKU=77715 and I know the price is high but everyone I
know who owns this jack swears by it. It is the most maneuverable floor jack you will have ever used
and will go under a Ferrari with a flat tire. 1 3/4" clearance in an emergency. This is just my opinion
but nothings too good for my pride and joy! :cheers: :flag
Old Nov 26, 2001 | 09:40 AM
Paul R's Avatar
Paul R
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Floor jack for the C5? (Jim Dawes)
I just bought the Griot's Garage low profile floor jack two weeks ago, and used it this weekend to change my oil. It fits under the car great and is extremely manuverable. It is pricey ($400), but it is built to last, and has a lifetime guarantee.
Old Nov 26, 2001 | 10:28 AM
wwashing's Avatar
wwashing
Default Re: Floor jack for the C5? (John Shiels)
Ditto. We all know that if you raise your car a lot you will be tempted to not use a jack stand sometime at some point. Please get a good jack. You may go an entire lifetime using a cheap jack and have no problem, but having a quality jack will increase you chances of not having a problem ever. An automobile jack is not a place to cut corners. IMO!
He's a place to get some information about jacks. http://www.hyjacks.com/index.html
Old Nov 26, 2001 | 11:29 AM
DUKE's Avatar
DUKE
Default Re: Floor jack for the C5? (Jim 47)
Jim:
:yesnod:
Got one of these puppies and its wonderful. Also is light and has the hard plastic wheels so as not to tear up your gragre floor. You can order those puck from an online hockey supplier for buck a piece.
Old Nov 28, 2001 | 07:15 PM
Speedluvr's Avatar
Speedluvr
6th Gear
Default Re: Floor jack for the C5? (DUKE)
I use two pieces of 1.5" thick wood. First I put down two pieces of .75" plywood and then the thicker stuff. Drive up onto it and then the jack fits under from the side. Still can't get it to go straight back from the front, too far under to move the jack handle.
Bill ;)
Old Nov 28, 2001 | 09:23 PM
bparker's Avatar
bparker
I like this one - :yesnod:
Second one down -
http://www.matcotools.com/Catalog/to...select=&page=1
Old Nov 28, 2001 | 11:08 PM
EDC's Avatar
EDC
Try http://www.ultimategarage.com
To Floor jack for the C5?
