I am torn: LG or QTP Headers
Old Dec 11, 2007 | 04:44 PM
teddyca's Avatar
teddyca
Default I am torn: LG or QTP Headers
We all know the LG's are bad @ss and this set has the high flow cat option as well, but for the same price I can have a full set of QTP's with no cats and Electronic cutouts. My logic says get the LG's, my ***** say get the QTP's. I want to have the cutouts and think that is bad ***. I need to run cats and figure for $120 I can order a set and make the QTP's good to go. If I want to even out the LG's it will cost me another $450 just to get a set of cutouts for it. What to do???
Old Dec 11, 2007 | 04:47 PM
uracowman's Avatar
uracowman
what the hell are QTPs?
Old Dec 11, 2007 | 04:48 PM
teddyca's Avatar
teddyca
http://www.quicktimeperformance.com/.../c5headers.php
Old Dec 11, 2007 | 06:29 PM
Chalky's Avatar
Chalky
St. Jude Donor '08-'09-'10
tri-Y's have been known as a torque producing header. In simple comparison, the Corvette C6R runs a tri-Y exhaust system with an engine that doesn't turn over 5400 RPM I believe.
I am just uncertain as to how well they will work at higher rpm's. Generally, you can't have it both ways.
Me, I still like the LG and Dynatech with the LSx motor.
Old Dec 11, 2007 | 06:40 PM
Pumba's Avatar
Pumba
L.G. Long Tubes
Old Dec 11, 2007 | 06:43 PM
kingsey's Avatar
kingsey
LG
Old Dec 11, 2007 | 07:08 PM
AU N EGL's Avatar
AU N EGL
Originally Posted by Pumba
L.G. Long Tubes
Old Dec 11, 2007 | 07:35 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
LGs without cats and then the cutouts. Lemme know if you want a set of the LGs, I'll ship 'em for free.
Jason
Old Dec 11, 2007 | 09:22 PM
vettenuts's Avatar
vettenuts
I am one of the few running QTP's here. They are well made quality headers with heavy gage tubes. They tuck up tight against the body. I have heard the cutouts when Barry (QTP) had them on his truck at Carlisle, holy crap that was great. My wife just wasn't as impressed though
QTP's are also all stainless and the headers themselves mate to the Random Tech cat/X-pipe so I think you can add cats later (talk to Barry first) and you can also go 3" if you want as well but with the cutouts you may not need to. They fit well, install easy and the front O2's plug right in almost where the stock location was so there is no contact with the tunnel plate or other installation issues that I have seen with other systems.
There are a few of us running QTP's but we don't talk much
Old Dec 11, 2007 | 09:23 PM
vettenuts's Avatar
vettenuts
Stock C5 exhaust manifolds (cast) are a Tri-Y design from GM, so there is something to the design. The Tri-Y design is also favored by Jack Burns.
Old Dec 12, 2007 | 12:07 AM
BATM4N's Avatar
BATM4N
QTP's are also all stainless and the headers themselves mate to the Random Tech cat/X-pipe so I think you can add cats later (talk to Barry first) and you can also go 3" if you want as well but with the cutouts you may not need to. They fit well, install easy and the front O2's plug right in almost where the stock location was so there is not contact with the tunnel plate or other installation issues that I have seen with other systems.
Do you have an automatic nuts? Been told the QTP's work a lot better with the A4's.
Old Dec 12, 2007 | 05:29 AM
vettenuts's Avatar
vettenuts
No, MN6. At the time I installed mine, there were no 3" cat back options, now there are a few. I think larger cats (on any header system) will help. However, the OP doesn't plan to run cats so I guess that is not an issue for him.
Old Dec 12, 2007 | 08:02 AM
AU N EGL's Avatar
AU N EGL
If you like the Stock tri-y stay with the stock header. There is not the room for an after maket tri-y long tube header. That is also why the stock headers are actully very good.
The C6R uses side pipes that come out in the back of the front wheel well, then down the side of the car.
Old Dec 12, 2007 | 11:10 AM
jordanfd's Avatar
jordanfd
LG'S FRANK
Old Dec 12, 2007 | 11:55 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
get the cut outs only save some cash
Do you plan on going with a cam? Then go with headers. If not id say just go for the cut outs.
Old Dec 12, 2007 | 12:04 PM
vettenuts's Avatar
vettenuts
I don't see the logic in this at all. Tri-Y's have several advantages over the 4 to 1 design.
Jack Burns
"While typical off-the-shelf street 4-into-1 headers do not have secondary pipes, Burns' research has proven repeatedly that his Tri-Y designs make more overall power over a broader rpm range. While traditional lines of thought have street enthusiasts knowing Tri-Y pipes make more bottom-end torque, further research by Burns into the design have resulted in headers making more power all across the rpm range. With more components as part of the Tri-Y design, more tuning possibilities exist, and therefore more potential lives within."
Old Dec 12, 2007 | 02:43 PM
Pumba's Avatar
Pumba
I just finished a conversation with Burns Stainless about a set of headers for a 427 LS engine.
My parameters were:
Bore: 4.185 inches
Stroke: 3.88 inches
Intake Valve size: 2.20 inches
Exhaust Valve size: 1.60 inches
Cam: 244 int - 256 exh - 118 degree LSA - 0.661 inch lift at the valve
Compression Ratio: 12.0:1
Usable rpm range: 3,500 to 7,500 rpms
Their recommendation is as follows for a 4-into-1 header:
Overall primary tube length: 28.5 inches
The first 1/3 of the tube should be:
- Tube diameter: 1 3/4 inches
- Tube length: 9.5 inches
The second 1/3 of the tube should be:
- Tube diameter: 1 7/8 inches
The final 1/3 of the tube should be:
- Tube diameter: 2 inches
- The 2-inch end of the primary tubes should come together in a 1 1/2 inch to 3 1/2 inch Merge-Megaphone collector that has a reverse cone at the end to aid in the transistion into my 3-inch X-pipe.
How many of us are driving around with a set of headers made to these specs?
To I am torn: LG or QTP Headers
Old Dec 12, 2007 | 02:57 PM
teddyca's Avatar
teddyca
I would love to run with the LG headers and use the QTP xpipe. Not sure if that would work. It is obvious the LG's are an overall better header, but are they that much better? for the price I am thinking the QTP's are an overall better deal with the cutout option in place. I am running a cam and other supporting mods. Thanks everyone for the info it is appreciated.
Old Dec 12, 2007 | 02:58 PM
AU N EGL's Avatar
AU N EGL
There is no doubt that the tri-y is a better system, it is the question of physical room in the C5 or C6 to have them fit.
Nick@Newtech's Avatar
Nick@Newtech
The cut outs will fail eventually. Mine did, my friends did, my techs did, a plethora of customers failed also, its inevitable. I would go with LGs or ARs.
Nick
