Fixed Orifice PCV "Valve"
Old Jan 4, 2008 | 12:45 AM
  #81
Dirty Howie's Avatar
Dirty Howie
Originally Posted by Dave68
Howie,
You might want to try this guy's advice:
I remember this.....Its also the most expensive alternative!!!!!
DH
Old Jan 4, 2008 | 07:43 PM
  #82
ZeeOSix's Avatar
ZeeOSix
Originally Posted by jpl99vert
I read previous post on the fixed orifice PVC valve's. Thought Id give it a try. Started leaking oil out the rear main. Replaced with stock ball unit, no more rear main leak.
Originally Posted by countslav
I guess they zipped right pass this....
Originally Posted by ArKay99
That WOULD make me change mine back too. Don't feel bad, I had nothing significant to add either.
I asked on the previous page if he could add any info. I PMed him to see if he could come back and elaborate on his experience.
Old Jan 4, 2008 | 07:48 PM
  #83
ZeeOSix's Avatar
ZeeOSix
After talking to Roadrebel (Phil) he told me it was a MUST to run a seperate PCV valve on my system. Regardless of what year it is. I would NOT run a check valve. The cracking pressure is to high. Just run a regular old GM PCV valve. It completely eliminated my problem.
Guess I don't quite follow what he's saying here ... is he talking with respect to the independent vacuum pump setup. Maybe he's talking about something else?
Old Jan 5, 2008 | 12:16 AM
  #84
ArKay99's Avatar
ArKay99
I'm building an LS2 stroker like Howie has and plan on doing some HPDE's once I get the car sorted out. I was hoping for some feedback on what I posted since I can't run the motor yet and confirm it. I had been fiddling with my PCV system for a while and had what seemed to be a pretty good setup for a h/c 346. However, this will be a built motor and will have looser clearances.
Old Jan 5, 2008 | 12:44 AM
  #85
vjjack04's Avatar
vjjack04
.....a few thoughts.....
1) This is why I don't particularly like giant catch can reservoirs as a way to avoid emptying it for one year - potentially too much oil and water sitting there for too long.
2) If you are using an actual PCV valve, you need to allow it to be lubricated by the oil, hence, the location of the catch can between the PCV valve and the intake.
3) I'm convinced that almost any catch can will catch more if the air and oil are allowed to cool somewhat. This is one reason why I mount my filters away from the intense heat of the engine. The other reason is that most coalescing filters with metal reservoirs have a maximum operating temperature of 175-180F. You can buy larger versions with 250F temp limits, but they are very expensive.
ok. I as I am sure alot of you are growing tired of this....Your points reveal you are thinking about it. First, if you have a catch can...consider emptying it periodically. (duh).... Secondly, the 'cooling' of the oil matters less, as the intent is to reduce oil consumption during hard acceleration/driving (the engine is hot). I can appreciate your pcv system...so now you have no problem...?
PS there is no requirement for the PCV valve (especially any fixed type) to be lubricated by (engine) oil.
I realize that the PCV decreases crank case pressure, but by definician it is considered a emission component; has little to do with WOT perfornmance.
Old Jan 5, 2008 | 12:45 AM
  #86
ZeeOSix's Avatar
ZeeOSix
I think this might be the way to go. You definately should go with an open breather if you're going to track the car, and retain the PCV/catch can on the intake manifold vacuum line.
http://forums.corvetteforum.com/show...7&postcount=48
Old Jan 5, 2008 | 04:43 PM
  #87
Dave68's Avatar
Dave68
Colder oil is more viscous and therefore easier to "trap". Besides, it can't hurt that the air being pulled into the intake is not nearly as hot as is the oil
Yes, the fixed type is really a flow-restricting orifice.
Agreed - It is without a doubt, most effective at anything less than WOT
