Blank TPS Codes
Old Jan 4, 2008 | 06:26 PM
CMC1998's Avatar
CMC1998
Default Blank TPS Codes
I had new rims put on my 1998 Coupe so I decided to get NEW TPS from Gene ( Thanks again). After getting a big magnet from Home Depot I went thru the procedure of learning the sensors. I got each wheel to beep as expected but there are no readings on the DIC. It displays Front L ___ R____ but no numbers. Does the car have to be driven awhile for the figures to show up ? Couldn't take it around the block because of snow / salt. Thanks for any help.
Old Jan 4, 2008 | 06:32 PM
Bill Dearborn's Avatar
Bill Dearborn
It has to be driven. Although you could probably use the magnet to turn the sensors on one at a time to see what pressure they are reading (dont do this in program mode). You wouldn't get a beep or anything but you could monitor the pressure display for each tire on the DIC to see if it changes from xxx to a reading of some sort.
Bill
Old Jan 4, 2008 | 09:21 PM
CMC1998's Avatar
CMC1998
Thanks Bill, I drove it up and down the driveway a few times and they started to show readings 1 by 1.
This site is awesome !
Old Jan 5, 2008 | 02:38 AM
DeeGee's Avatar
DeeGee
Just for info, the TPS batteries go into hibernation mode when the car has been stationary for a minute. That extends the battery life. They restart after a few minutes on the move which is why you have a lag until the DIC gives you a reading.
To Blank TPS Codes
