Optima Battery
Old Jan 8, 2008 | 07:47 AM
Irish Whiskey's Avatar
Irish Whiskey
Default Optima Battery
Had for a little over three years (red one) -starts the car fine. However, if I sit for a while with the radio on; leave the cell phone cord plugged in; leave the door ajar,etc it will go dead in less than ten minutes. If I don't leave any of these "drains" on it, it's fine. Voltmeter reads high 13's and low 14's all the time ---is this just a piece of crap battery??
Is there another one that is recommended?
Old Jan 8, 2008 | 08:41 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
shouldn't drain to dead that quickley IMO I keep a digital charger on mine when I wont be driving the car for several days............might want to have it load tested? Mine has been fine doing it the way i do for 5 years now.
Old Jan 8, 2008 | 08:46 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
Do a search using - battery - There is more information than you probably want to know.
Old Jan 8, 2008 | 08:57 AM
99 vett babycar's Avatar
99 vett babycar
[QUOTE=Irish Whiskey;-is this just a piece of crap battery??
[/QUOTE]
YES
Old Jan 8, 2008 | 10:16 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
If you leave the radio on by having the key in the "accessory" position, this causes teh fuel system to pressurise which uses a significant amount of power. Granted this shouldn't drain your battery that quickly but then again the red top doesn't have a fantastic standby time. I'm thinking of switching mine to the yellow top for better standby.
Old Jan 8, 2008 | 10:58 AM
TEXHAWK0's Avatar
TEXHAWK0
As more Optima batteries are in service, it becomes apparent that they have failures just like all other batteries.
I just stayed with the AC Delco, which now has a 50 month replacement warranty if you buy their professional battery. The only advantage I ever saw in going to an Optima was that it was not a side post, so it is less likely to leak and damage other things.
My car is a 2004, so I don't have that problem.
You might consider changing battery cables so you can go to a top post design, and stay with the Delco.
Old Jan 8, 2008 | 12:02 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
I had a Red Top for just under 3 years and it was fine for the first year or two, but later, if I didn't keep a charger on it and let it sit for a week or so, it would be too weak to start the car. Seems, as they get older, once they are drained that they won't hold a charge. Swapped it for a Sears DieHard Platinum.
Old Jan 8, 2008 | 03:23 PM
Dave68's Avatar
Dave68
AGM batteries in general hate to be drained much more than the normal electronics current requirements. My AC Delco AGM is more than six and a half years old and still starts the car every time. However, AC Delco abandoned the AGM for a reason; obviously, Optima hasn't solved its "drainability" issues, as evidenced by the hundreds of complaints I've seen on the forum.
The current (for the last few years) AC Delco lead acid Professional battery has a strengthened case, especially at the side posts and, as was mentioned above, carries a 50-month free replacement warranty - best anywhere.
For $90-$100, it represents a much better value than any AGM battery, IMO. This is what I will buy when my battery turns 7 or dies, whichever comes first!
Old Jan 8, 2008 | 04:23 PM
DeeGee's Avatar
DeeGee
The big plus for the Red Top is it wont leak
The down side is it wont cope well once its drained.
Buy a battery tender and the Red Top will see you through many years of service.
Old Jan 8, 2008 | 07:33 PM
The battery definitely should not go dead that fast - I'd have to say you do have a bad battery (at least get it checked).
I've had my Optima Red Top in mine for over 6 years and it still performs well. I keep a Battery Tender Plus on it when it is sitting in the garage.
Old Jan 8, 2008 | 10:44 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
A battery has a "designed" storage carrying capacity and a specific current carrying capacity. If the battery is fully charged and not compromised, it should be able to maintain a specific cold cranking current, able to maintain a specific low level current draw for a specific time period and be able to recover quickly once discharged.
Almost Any Auto-parts store can LOAD test a battery and tell you if the battery is good fair or BAD! Sounds like your battery cant maintain a deep enough charge most likely due to a damaged or sulfated cell.
I just purchased an completely automatic battery charger from Home Depot that has 2,10, 20 and a 60 amp boost. It can charge a number of different type of batteries and can rejuvenate sulfated batteries. I tested it out on my jeeps battery that was on its last leg and WOW, it works a LOT better!!!
Old Jan 10, 2008 | 04:22 AM
mdhmi's Avatar
mdhmi
I had to replace my Redtop last year as well. 3 years of service is fine.
Old Jan 10, 2008 | 11:28 AM
spider94r's Avatar
spider94r
AGM batteries don't take well to fast charges when they are flat. The best way to charge an AGM battery is a slow 2-amp charge for 24 hours. I wouldn't declare an AGM battery "bad" until you've done this.
I think many serviceable AGM batteries have been wrongfully thrown away by people who tried a quick 10-amp charge or just jump-started their car and drove it for a while and were disappointed in the results.
Old Jan 10, 2008 | 11:57 AM
mcgilles's Avatar
mcgilles
I have a blue top optima in my SHO and a yellow in my C5. both ( the blue in particular) has been drained completely on many occasions, they always charge right back up and perform perfectly afterwards. I thought the blue and yellow at least were supposed to be "deep cycle" so they are designed to recover from being drained. I always thought they were better for that than a lead acid battery which looses some life any time it is allowed to drain completely.
Old Jan 10, 2008 | 12:25 PM
MattB's Avatar
MattB
Ya, not my experiance. Wish it was, but my third red top in two years is dead and I'm moving on...
Old Jan 10, 2008 | 02:51 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
do you have an after market stereo system with additional amplifiers?
Old Jan 10, 2008 | 04:16 PM
Dave68's Avatar
Dave68
Keep in mind that while a "deep-cycle" battery is designed to be able to be deep-discharged by high current draw electronics, this type of battery has a shorter life than most standard batteries.
For example, standard lead acid batteries often last 6-7 years. rarely will you EVER hear of a deep cycle battery lasying more than 4 or 5.
To Optima Battery
Old Jan 10, 2008 | 04:41 PM
DeeGee's Avatar
DeeGee
The other issue is what type of use does it get
If you start up, drive 3 miles at slow speed and shut down it'll be harder on the battery than driving 30 miles at 70 mph on the freeway.
Old Jan 10, 2008 | 04:43 PM
Svelte_C5's Avatar
Svelte_C5
St. Jude Donor '09
Why is this hard on a battery? I do this twice a day. I live about 2 miles from work and my c5 is my DD.
Old Jan 10, 2008 | 05:35 PM
HIGHRPM's Avatar
HIGHRPM
Optimas used to be OK....now they are unreliable. I went through one red top and two yellow tops in less than 1 1/2 years. If you let them completely discharge ONCE they sulphate up and will never again recharge to full capacity. I now use a heavy duty Delco....has worked flawlessly for two years.
