CEL When Steering Wheel turned left
I know I have a right front turn lamp socket with a short (new front light harness should be here tomorrow at ten) all the other grounds/harness look good - BUT...
There has not ever been a battery leak and all looks good under the battery now.
I can get a CEL flash and a stumble when I turn the wheel left with vigor and sometimes I get a CEL flash and stumble when I hit a bump - especially when turning left. Lately, I have gotten code C1278 and "Service Traction Control" with some of these "stumbles". We replaced three out of 4 wheel bearings last weekend due to play (this is a NASA TT car).
The dash seems to lose power for a second and the Tach/Speedo do a "mad sweep" for a second before returning to normal - car loses power and then recovers. Resets the avg MPG also
Based on a RAFT tip we will check the IPC ground tomorrow also.
Could this be a steering sensor?
Any tips or advice greatly needed.
Another area of CONCERN is the pass and drivers door wiring harnesses. Pop the accordion tube off on both ends,,pull the connectors out of the door frame pocketand examine the connectors for bare wires and loose pins.
What DTCs are you seeing when the issue happens??? Please list them ALL!!!!
As always, check your chassis grounds.
Let us know if this advice helps you!
BC
We did notice a "hiss" sound around the battery after the car was shut off...I had it tested about 8 weeks back when I fired off the new engine. It tested fine then.
I checked the underhood grounds - is there an easy way to get those bad boys apart? They were basically OK - nothing even close to the photos in the thread.
I will be checking the rest of the grounds as I can access them...
I have had
C1278
U1016
U1094 (a lot!)
U1064
B1001
--516 the VSS code - it, and its wire, checks fine.
Both sets of O2 sensors - I think I solved them
At the moment the flickering CEL does not set a code - just stumbles the car...
The BCM is dry and clean...
I will check the doors...
I really did do all the "free" things first
As I get "fresh codes" I will report
There are a TON of electrical connectors outboard of the battery. Give them a close look.
BC
BC
I did find a where it looks like my new RPM transmission
is leaking back by the differential and it looks like my oil cooler block is up to its old tricks of leaking again - but nothing, I can locate, seems to be doing the electrical gremlin.But when I took it out for a ride - it lost power for a millisecond (easy to tell since the avg mpg freezes in the single digits) but no CEL. A few minutes later I was able to get the CEL to come on, service tractions control and it threw only the C1278 H code with a sharp left turn of the wheel.
The car threw the following codes
U1016 H
U1064 H
U1094 H
when the headers cool I should be able to start checking that bundle
I really hope this is the problem!
It was a real booger to get to and repair with headers on the car but it has not done it again since I repaired it today
If I am lucky it will be fixed now
.Thanks for all the advice and encouragement
BTW, looks like from your banter you may have done a tour at LH or UH?
77th Tactical Fighter Squadron at UH.....amongst others...
