Removing AIR system
Old Oct 18, 2008 | 05:28 PM
  #41
fst85vtt's Avatar
fst85vtt
Old Oct 18, 2008 | 10:24 PM
  #42
ClockworkC5's Avatar
ClockworkC5
i cut the pipes off the the flange, put in a copper penny, used some high temp gasket material, and used the original bolts to fasten together. disconnected smog pump. tuend everything out. slp short tube headers and no problems.
Old Oct 22, 2013 | 08:47 PM
  #43
94z28camaro's Avatar
94z28camaro
St. Jude Donor '15
I feel bad resurrecting any of these crazy old threads... however I need to know if the Tech II can remove the AIR codes. I've searched and searched with every result saying LS1Edit or HPTuners, however I'd prefer not to drop $100+ on a license when I can use a Tech II for almost nothing.
