Ported heads; please step inside
Old Jan 14, 2008 | 12:11 PM
LDB C5's Avatar
LDB C5
Default Ported heads; please step inside
Installing ported Trick flow 215s. I noticed that the threaded holes for the rocker arm bolts go through into the intake ports. What is everyone using as a thread sealer? Blue Loc-Tite? Something else?
Old Jan 14, 2008 | 01:22 PM
Mike Francoeur's Avatar
Mike Francoeur
Sent ya a PM incase you dont revisit this...
Old Jan 14, 2008 | 01:29 PM
C5B's Avatar
C5B
Yeah, this is normal. I just used blue loctite, but that's cuz I don't have a real answer yet AND, I still need to fine tune the valvetrain noise, so I don't want to lock the whole thing down yet.
Further question, that I think will be valuable for you in the future: All, when you remove the rocker arms, some loctite will probably fall into the runner. Now, I forget if the protrusion was in the intake or exhaust. If exhaust... who cares But intake? Is this trouble waiting to happen?
EDIT: GOod lord, you said intake!! Argh, rough weekend!
- Colby
Old Jan 14, 2008 | 03:34 PM
thetorch's Avatar
thetorch
Red Loctite 567
Old Jan 14, 2008 | 03:39 PM
LDB C5's Avatar
LDB C5
Originally Posted by thetorch
Red Loctite
Red? Isn't that pretty permanent?
Old Jan 14, 2008 | 03:48 PM
MattB's Avatar
MattB
Permanent is more of a marketing term in this case...
The normal heat from engine takes its toll on the red locktite and it is fairly easy to remove.
Old Jan 14, 2008 | 03:55 PM
vettenuts's Avatar
vettenuts
While the heads are off the car, also install your stock bolts to make sure they don't protrude into the intake port. Clean the bolt good though.
I plan on using and have used blue loctite. You just have to make sure the threads are clean on the bolts and the heads.
Old Jan 14, 2008 | 04:22 PM
LDB C5's Avatar
LDB C5
I think the blue would be a better plan than the red. Red will make it difficult to get the bolt out again.
Someone also suggested teflon tape? Not sure how that would take the heat, but they use it on frying pans
Old Jan 14, 2008 | 04:44 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Loctite 542. It is both a sealant and medium-strength threadlocker...intended for fine pitch threads.
Old Jan 14, 2008 | 04:54 PM
thetorch's Avatar
thetorch
I've got Crane roller rockers and have no problems removing the studs.
Old Jan 14, 2008 | 05:10 PM
vettenuts's Avatar
vettenuts
Ahhh, hence the red.
Old Jan 14, 2008 | 06:55 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I use thread sealant on the threads and some red loctite up by the head of the bolt.
To Ported heads; please step inside
