Foglight surround/ screen area question
Old Jan 17, 2008 | 05:23 AM
XXXLTRP's Avatar
XXXLTRP
Default Foglight surround/ screen area question
I have a '99 FRC with fog lights. I want to put screens in there to get some more air to the airfilter. I already found the black screens I want in other threads here. What holds the fog light surrounds in place? How can I remove them? Can I keep the foglights behind the racemesh screens?
Edit: I don't want to cut the area where the license plate goes, well not yet.
Old Jan 17, 2008 | 10:20 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You have to go from underneath the Vette in order to access the housings.
There is a triangular piece on each side as well as loosening the shroud at the bottom in order to access it.
They are held in by 4 small 10mm screws!
As for the screens they simply go in from the front with double sided tape!
Here look at cajundudes instructions to get an idea:
http://www.cajundude.com/vararam.htm
Thanks,Matt
Old Jan 17, 2008 | 03:19 PM
XXXLTRP's Avatar
XXXLTRP
Excellent! Thanks!
Old Jan 17, 2008 | 03:36 PM
AU N EGL's Avatar
AU N EGL
I just took a utility knife with razor blade and cut the plastic of the fog light shroud along the back edge. The part were it is flat and just curves over to that little notch just to the inside of the Fog light. There I just made a straight line cut.
double sided tape for the screen. Done in under 30 mins
To Foglight surround/ screen area question
