Stumbles when accellerating hard
Old Jan 30, 2008 | 04:34 PM
barker2036's Avatar
barker2036
Default Stumbles when accellerating hard
I have a 97 6M, that drives like a champ until I get put the pedal to the floor, that when it stumbles (well below red line) like it is hitting the rev limiter. I just changed plugs and wires to correct this, but the problem still exists. Any ideas?
Old Jan 30, 2008 | 05:09 PM
BowTieRocket's Avatar
BowTieRocket
Traction control? That's the obvious guess, though your post doesn't indicate what you're doing beyond standing on the gas. Traction control works by de-powering the engine, so you get a stumble.
That's my best guess. If you're under hard acceleration, and losing traction, try turning TC off with the button on the console. Easy check, and if that's it, well, you have a cheap answer.
Good luck!
Old Jan 30, 2008 | 05:38 PM
zo6_yellow's Avatar
zo6_yellow
I am having the same problem with my 01, but I will try with TC off. Thanks
Old Jan 30, 2008 | 07:59 PM
barker2036's Avatar
barker2036
Took the TC off and problem still exists. Its only when I put it to the floor from 25mph on, I havent tried from a dead start but am sure I will get the same response. Any ideas?
Old Jan 30, 2008 | 10:26 PM
BowTieRocket
Sorry it didn't help. That was my one shot. Check the plug gap. I've seen that cause stumbling.
There are some clever folks on this forum. Maybe a better one will jump up. For me, I like the plug check. My Shelby had this little problem, just like you're describing. Turned out the plugs were gapped way wrong. That was enough. New engine, too. I just got in a hurry (or got sidetracked) and forgot to check the gaps before installing. Regapped, and as Mazda says, zoom zoom zoom.
Good luck. If no codes, it's probably something pretty straightforward. Oh, if the plugs are too light, you may be running lean. That will cause the symptom you're seeing, too. Do check the codes - there are instructions here on the forum, for just a quick search ("read codes" or something similar).
I rented a new Shelby last year. When it ran up against the rev limiter or the traction control, it stumbled just like you describe. Just went out and got into my car a little - second gear and the trac control did it again. It was a guess, but one I've seen personally.
I'll keep looking for your results.
Old Jan 30, 2008 | 10:44 PM
RdDragn2's Avatar
RdDragn2
What codes are you throwing if any?
It could be a lot of things. Such as a knock sensor, or many other things.
Here is a link on how to read your codes if you don't already know:
http://www.97vette.com/howto/codes/index.html
Old Jan 31, 2008 | 10:14 AM
Slowhawk's Avatar
0Slowhawk
Former Vendor
Could be anything.You need someone to scan it while driving.I've seen alot of older cars have bad MA meter's which will do this or you could have a bad coil. If I had my scanner on it I could tell you in less than 5 minutes.
Old Jan 31, 2008 | 11:18 AM
BlackZ06's Avatar
BlackZ06
Which plugs and wires did you put in, and what plug gap?
Take a look and see if the PCM has posted any codes ... if you don't know the procedure, go here ....
https://www.corvetteforum.com/techti...D=26&TopicID=1
Be sure to post the entire code, such as P0300C
I'd also check for any air leaks between the MAF (located above the radiator) and the throttle body (located on the front of the engine). Air leaking in is "unmetered" air, and will cause the engine to run lean, making it feel like it is stumbling. It may be that the higher vacumn at WOT is opening up the "leak". Main thing, though, check for codes.
Old Jan 31, 2008 | 07:18 PM
racetchr's Avatar
racetchr
Have you been driving ez for a few days? Could just be "loaded" up.
Old Jan 31, 2008 | 08:47 PM
ZShot's Avatar
ZShot
My bet is on a slipping clutch.
To Stumbles when accellerating hard
