gear selector indicator problem
Old Feb 16, 2008 | 03:00 PM
devans's Avatar
devans
4th Gear
Default gear selector indicator problem
my 1997 c5 no longer shows what gear it is in. the red line stays in one gear, no matter what gear you are in. my local chev dealer wants $750.00 to fix the "unit"
any help or suggestions?
thanks
dave.evans@wellsfargo.com
Old Feb 17, 2008 | 02:06 AM
DeeGee's Avatar
DeeGee
Fill out your profile so members can target their advice
I assume you mean the tell tale on the A4 selector?
Old Feb 17, 2008 | 02:23 AM
Bounty's Avatar
Bounty
thanks
Same thing happened to my 98 A4. The little red or orange gear indicator is a little plastic piece which is easily broken. Remove the center console, shifter boot, and expose the shifter. You'll see it in pieces right away. I found a used shifter at a Corvette salvage yard for $100 because the dealer would not sell me just the plastic piece.
Hope this helps...
Old Feb 17, 2008 | 10:13 AM
middlebrookgt's Avatar
middlebrookgt
I agree. The little plastic indicator arrow is broken. I missed out on a new assembly for $35 on the auction site, and am looking for another one to swap out. I tried to glue the indicator, but it's about impossible to keep in place while you put everything back together.
Old Feb 17, 2008 | 11:55 AM
BlackZ06's Avatar
BlackZ06
thanks
Find a new dealer .... the GM retail for that part is about $200.00 (I believe it is part # 12562754 - but verify that before ordering) so they are soaking you for about $500.00 in labor ... that is WAY high ... I'd say a couple of hours MAX ..... so should be more like $400.00 (total) to replace ....
To gear selector indicator problem
