C5 Intercooled ProCharger system now available!
In term of labor, ATI estimates between 6 to 12 hrs. One shop quoted me under $1000 for installation. I am hoping around $500.
We don't really do any financing but do take all major credit cards :)
Tom
www.tbyrnemotorsports.com
Joe
Joe
Q: Where is it mounted?
A: On the passenger's side.
Q: How easy is it to do a pulley change?
A: Shouldn't be to bad. The head unit is mounted in backwards so it will need to be pulled off to get to the pulley.
Q: Are the horsepower numbers quoted flywheel or rear wheel?
A: They are flywheel.
Q: Installation time?
A: Install time should take 8-10 hours.
Q: Will this kit work on an Z06?
A: They haven't installed one on a Z06 so they're not sure yet.
Q: Where does the kit pull air in?
A: The tech wasn't sure (hadn't taken a good look under the car yet), but he assured me that they wouldn't design the kit in a way that would cause a problem if the car was driven in the rain.
Q: When will the introductory prices be changing and by how much?
A: Nothing has been set yet, but the kits will probably go up by about $500. They are not sure when the introductory prices will be ending.
Hope this covers most of the questions that have been posted.
Tom
Tom
In all seriousness, if they need a Z06 to test with, I will drive my car to them as long as they give me a SERIOUS discount. I will let them tune and tinker with it for a week.
I see the compression/timing being the only issue since the Z is 11:1... I would assume they could pull another 1.5 degs of overall advance and probably eliminate detonation...
Please, let me know if they'd be interested in using me as a guinea pig?
