C5 Intercooled ProCharger system now available!
Also, does ATI have any plans to get a CARB EO# from California? TIA
ATI is working on making this kit CARB legal in CA, but of course that usually takes awhile.
Can we get a "heavy duty" main bracket or will the current bracket suffice??
Can we get an 8 rib drive belt system???
how much extra would they be???
Tom`s description is "Twin Highflow air to air intercooler" the picture
gas one big intercooler in front of radiator ?
I.e. what would be a good combination of purpose built motor and s/c and what kind of power would you expect with it?
Tom
T BYRNE MOTORSPORTS - www.tbyrnemotorsports.com
LT1 and LS1 Sales and Service
Hours 9AM-5PM EST Monday-Friday.
Order line - 1-877-4-TBYRNE
2002 Supercharged 8.1 Suburban - Project underway now!
2001 Supercharged 6.0 Suburban-15.87 @ 88.41
2000 Millennium Yellow C5 convertible- 11.92 @ 115.01
1998 Vortech powered Z-28- 10.89 @ 130.03 - 9s coming soon!
We usually don't refer to the D-1SC as a stage 2 kit but alot of people think of it that way :) I don't believe ATI will be offering a heavy duty main bracket or 8 rib drive system but I can check on this.
If you have a built motor you could go with the D-1SC and crank the boost up to 10-15#. At that point I'd be expecting the car to make over 600 rear wheel horsepower.
Tom
Tom,
thanks for the replies.. I am alil confused. I thought the D1SC was stage 2?? I think I have seen the f=body guys refer to them as such... What would be stage 2 then??
Also, do you know what pulley sizes refer to each psi?? I think th e3.20 pulley is the 10 psi one?? I basically want to have the ability to run a psi pulley and a 12+ psi pulley on a BUILT motor. So I guess I would order an extra pulley or two. How much are they??
thanks... :cheers:
Tom
Need a second job :)
650rwhp without NOS..........nice thing.
And what about a little NOS on top of that :D
Michael
My shop is located in San Jose, CA and we will install do the Pro-Charger install on your vette.
I have not yet done a Procharger C5, but we have done them on lots of other applications, and have done more Vortec's on LS1 F-bodies than i can count.
Email me for more info
Lowend65@cs.com
One other thing... Pro-Charger claims that all of their kits go on in 8-12 hours. In my experiance this is rarely the case, they generally take quite a bit more time. I'm guessing this gonna be a 15-20 hour job based on what I have seen in the past.
Tom
Tom
If you have a H&C pkg. reprogrammed for 6800 rev. limiter, would that
be a problem for this SC setup ?
x psi boost at what RPM ???
I guess Turbo is easier that way, because you can dial in max boost, and even with higher RPM you still be safe ?
Any TT guys that can confirm this ?
GPII
[Modified by GWPII, 2:50 PM 12/11/2001]
Tom
Maybe some install pics ?
Tom
Also, what kind of RWHP do you think I would see on an A4 with the usual bolt-ons?
