View Poll Results: C5 Reliability Issues....
I have had very few or no major mechanical issues!
65.06%
I have had some engine related mechanical issues
9.09%
I have had some transmission / driveline related issues
14.06%
I have had some electrical related issues
31.68%
Multiple Choice Poll. Voters: 704. You may not vote on this poll
C5 Reliability Poll....
Old Jul 11, 2012 | 10:41 PM
  #121
Trios's Avatar
Trios
Bought the car with 63k on it, now up to 98k. Had a problem with the wiring in the accordion tube dropping my class 2 serial bus, and a fried PCM. The PCM was not the car's fault, however; some idiot previous owner decided that instead of pulling the inner fender cover to access the PCM, they would be a complete jerk to the next guy and cut a hole in the general area of the PCM to install their crappy "tuner chip" thing inline with the PCM wiring, and then left it open to the elements. Then they sell it to me here in Washington state where it becomes a rain-or-shine daily driver and the story tells itself...
Old Jul 12, 2012 | 12:39 AM
  #122
Chris Arnold's Avatar
Chris Arnold
That's ridiculous that they didn't bother to tell you. Some people's kids...
Old Jul 12, 2012 | 12:42 AM
  #123
Chris Arnold
Originally Posted by kalayaan12
No real drama on my 1998 convertible w/ 36,000 miles:
1) Left rear TPMS sensor replaced
2) Steering column lock left me stranded
3) Accessory drive belt "squeal" drove me insane - it took a Gatorback belt to fix it finally after exhausting everything else...
4) Replaced car battery a few times (it sits alot between deployments!)
5) Poor top fit - driver window closes on the canvas and has worn and frayed the corner
6) Fuel gage jumps to empty unexpectedly more and more often
7) Excessive wear on driver seat bolster
8) Seat track has too much freeplay
9) Side window / roof weatherseal leaks like a sieve on driver's side
Other than that - not bad!
Search how to adjust the window. It's pretty straightforward.
Old Jul 12, 2012 | 11:55 AM
  #124
AFTRBRNR's Avatar
AFTRBRNR
Mostly electrical related issues that pop up. Eats batteries like a toddler eats candy.
I drive in the rain!
106,000 miles on the frame. I drive this car very hard. I take off at stoplights all the time. I'm actually surprised more things aren't broken.
I have had a new motor installed because I blew the original, that new motor was too powerful for the stock transmission and melted the clutches, so I have a new transmission.
I caused the expensive problems... GM caused the annoying problems.
Overall very reliable for the abuse I put it through and very easy to fix problems on this car as long as you have enough money to throw on it!
Old Jul 12, 2012 | 11:27 PM
  #125
AvidSkier's Avatar
AvidSkier
6th Gear
Bought my 2004 Verti in 2006 with 18k mileage. Changed battery a couple of times and changed the coolant reservoir tank this past April. I have 82k miles now. Drive every day, rain or shine. Only issue now is the damn radio lock! Coming up on 100k so will be doing the maintenance.
Other than that, this car has been awesome. Better than I actually thought since this is my first American car. Love it!
Old Jul 12, 2012 | 11:46 PM
  #126
jrose7004's Avatar
jrose7004
I've had zero problems with this car.
Old Jul 13, 2012 | 02:42 AM
  #127
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Most window issues for going up and down. Its called use or loose. You have to put them up and down when you down use it that much or the armature gets a dead spot on the motor.
Old Jul 13, 2012 | 11:12 AM
  #128
phil hunter's Avatar
phil hunter
Owned my 2001 since new. Only problem was left side differential leak. Oh, I also repalced the battery after 10 years. Overall, trouble free car.
Phil
Old Jul 13, 2012 | 11:35 PM
  #129
OkieBikerDude's Avatar
OkieBikerDude
Repaired EBCM and had the passengers side door lock relay and control module replaced. '02 with 40K miles that spends most of its life in a heated/cooled garage. It has been driven in the rain a few times while on road trips (most of the miles).
Okie
Old Jul 14, 2012 | 05:33 PM
  #130
funky_thumper's Avatar
funky_thumper
Default 2002 Red Coupe
I bought mine used in 2010 with 28k miles on it from folks that I know. They were aware of some issues but thought they were fixed. The issue came back - reduced engine power/service traction control. Just recently found the cause. Replaced the TAC. Everything has been great after that. I've only put 3.5k miles on it since I bought it (mostly due to the TAC module). I have modded the brakes (new slotted and dimpled rotors, Hawks HPS and braided brake hoses) and put in some radioflyer lights. Other than that, it's stock. It's pretty much a fair weather car. I do expect that there will be more issues down the road. After all, it's a 10 year old car. However, the fact that it's a vette, it looks,rides and drives great and I enjoy the challenge of the next fix (so long as I can afford it) - you don't get that with any other "average" car. And that's coming from an ex mopar guy. BTW, having this forum around makes owning a vette a much sweeter experience! Bill Curlee, I salute you
Old Jul 24, 2012 | 12:04 AM
  #131
93droptop's Avatar
93droptop
Default Mostly Electrical
01 Z06, purchased 2 years ago with 24K, now up to 46K - HVAC display with cold solder joints (fixed once, it's at it again), ignition switch failed, oil pressure sending unit pegs display, power seat wiggles, corroded grounds lead to erroneous codes in DIC a couple times a week.
Old Jul 24, 2012 | 10:12 AM
  #132
zwaldo's Avatar
zwaldo
had the car for 4 1/2 years. 47,000-87,000 miles. had to replace the hazard switch, install column lock bypass, rear wheel bearing, battery, sold the car with the 40100 code or whatever it was that has to do with emissions.
Old Jul 24, 2012 | 03:15 PM
  #133
Dave68's Avatar
Dave68
Phil
Now you are one lucky man! I've never heard of or seen any C5 that did NOT have an EBCM issue or a column lock malfunction. And how about the fade-to-nothing temperature display? Is that actually still visible? How about your smog pump check valve? I've gone through 2 and am on my third.
Old Jul 24, 2012 | 08:13 PM
  #134
phil hunter
Sorry Dave, None of the listed problems have happened to my car. As stated the only repair was the leaking differential for which there is a TSB. Been very trouble free and that is despite my adding a double din radio with 12" sub and amp and an A&A V3 Si supercharger.
Phil
Old Jul 24, 2012 | 09:09 PM
  #135
Jumper11's Avatar
Jumper11
2002 M6 with 55K, Borla exhaust, dual K&M aircleaner
1) Fuel gage issues (goes to zero and ran out of gas with 1/4 indicated)
2) EBCM (Got ABFIXER rebuild)
3) Column Lock (LMC5R)
4) HVAC Display dim (resoulder chips)
Not bad, drive it almost everyday and try not to drive it in the rain. Great car!!!
Old Jul 24, 2012 | 09:36 PM
  #136
Chuck Beatty's Avatar
Chuck Beatty
8th Gear
Default Electrical issues 2001 C5
Replaced both window motors this summer, steering column locked up 5 years ago. Heads up as well as 12 disc player out of commission past year. Replaced 3 batteries. Factory wheels replaced by Chevrolet those pitted too, and finally glass top turned a dull black.
Original owner 32,000 6 speed, keeping the car, but will never own another Corvette.
Chuck / Virginia
Old Jul 25, 2012 | 02:17 PM
  #137
moncal90's Avatar
moncal90
I ordered my 2003 and I have just over 40K on her now. The only issues I've had has been the rear seal leak and I've had 4 new radio units installed (I now have an aftermarket H/U). All of that was replaced under warranty. I just had my driver side window motor go out so just at 10 years I think the car has been really solid. I love this car!
To C5 Reliability Poll....
Old Jul 25, 2012 | 03:09 PM
  #138
Dave68's Avatar
Dave68
Phil
You ARE lucky, Phil,
My latest repair/replacement was the driver's side headlight motor gear. I replaced both sides with bronze versions. For many of the things I mentioned, it's not a question of "if" they will fail. Rather, it's "when" they will fail. My car has about 48,000 miles on it.
Dave
Old Jul 25, 2012 | 03:21 PM
  #139
QCVette's Avatar
QCVette
Active Streak: 90 Days
Harmonic balancer failed on my '99 FRC at 30k miles.
Other than that my two C5's have been pretty good. Only minor stuff like an outside temp sensor and an O2 sensor failure (due to routing wires around LG headers).
I did some preventive measures like the column lock bypass on both.
Old Jul 25, 2012 | 03:49 PM
  #140
VinceBlack's Avatar
VinceBlack
Here are the issues I've had and the approximate mileage when each happened. My Z06 is garaged and has only been driven in rain a handful of times since I acquired it in February of 2006:
EBCM @ 45,000 miles
Water Pump @ 60,000 miles
Oil Pressure Sensor @ 74,000 (just happened, not fixed)
Pulleys @ 55,000 miles
Failed Gear in Left Headlight Motor @ 45,000 miles
Intermittent Turn Signal Failure @ 74,000 (just happened, not looking forward to fixing that)
