View Poll Results: C5 Reliability Issues....
I have had very few or no major mechanical issues!
65.06%
I have had some engine related mechanical issues
9.09%
I have had some transmission / driveline related issues
14.06%
I have had some electrical related issues
31.68%
Multiple Choice Poll. Voters: 704. You may not vote on this poll
C5 Reliability Poll....
Old Oct 12, 2010 | 06:33 PM
  #81
3rd_Vette's Avatar
3rd_Vette
Pull Key Wait 10 Sec... New Optima Yellow Top cured that!
CLB (still need to install) *in glove box*
Still on original tires (flame suit on) but plan on new wheels and tires in the spring
18k miles and I love this car! By far the best Vette yet that Ive owned
Old Oct 12, 2010 | 08:49 PM
  #82
ZZ06's Avatar
ZZ06
01ZO6 coloumn lock TWICE after recall. Installed the CBL. Replaced A/C compressor. Belts and battery (thats a given), stock clutch went at 81k......but i think that was do to mods (replaced with Monster Stage3). Replaced belt tensioner. Had the ABS fixer mod. Bought her at 45k in 2007 now has 90k 2010. She's me DD.
Old Oct 12, 2010 | 10:20 PM
  #83
wrmiles's Avatar
wrmiles
2002 MN6 coupe with 103K miles (bought new)
1. LDCM (warrenty)
2. Rear axle seal
3. EBCM ABS fixer (currently goes out occasionally)
4. Fuel gauge to zero (currently RH transfer plugged)
5. Turn signals occasionally due to hazard switch
6. One battery
Old Oct 13, 2010 | 07:55 AM
  #84
vafirevet's Avatar
vafirevet
2001 with 39,000 miles weekend car. Issues:
1) door lock board failed to lock-fix by Bakerfield's info
2) replaced original battery after nine years
3) gas guage went to empty- fixed with Techron additive
4) CLB -fixed with blocker
Very happy with reliability... Great car!
Old Oct 13, 2010 | 09:15 AM
  #85
rebelheart's Avatar
rebelheart
The battery went bad after 5 years and the fuel tank recall is it!
Old Oct 14, 2010 | 04:15 PM
  #86
rried2tall's Avatar
rried2tall
Default 2003 Corvette issues
2003 vette, 56000 miles, pull key wait 10 seconds every once in a while, bad thermostat had to change, small leak on differincial, change fluid went away, catchy shift on six speed changed fluid got much better, all in all very good car.
Ron
Old Oct 14, 2010 | 05:18 PM
  #87
ericdwong's Avatar
ericdwong
98 Coupe, have had it since 2002, my only car. Driven daily, sun, rain, snow. 168k miles.
I voted twice because I've had both. Lots of minor little issues, most I'm able to correct on my own. Biggest failure I had was the clutch master cylinder died. Drove home in 2nd gear then promptly fixed the car.
I've found as these cars age you'll get more squeeks and rattles. And then the body panels (most of which are glued together) may start leaking. Takes some effort to correct them using silicone and finding it. So a high mileage C5 is not for someone who has no tools or no time.
Old Jan 26, 2011 | 10:07 AM
  #88
jimcork1's Avatar
jimcork1
Default 99 Nassau Blue bought new
Issues electrical were
Memory seats. (poor problem solving by dealer 6 trips) I found cut wire no more issues
DS door control module for windows twice. (I used quick fix new relay 2nd time)
OEM battery leaked on CPS. R&R optima clean prime paint frame etc all ok for last 7 yrs
AC tensioner squeeked design on bearing
I wish all cars were as reliable as my vet. I own a Mercedes E500 and it doesn't hold a candle to my vet. Planning to buy Caddy next to replace E500 thinking it will be as reliable as the VET
My vet is new reliability bench mark for me, 87,000 miles and still going.
Old Jan 26, 2011 | 04:54 PM
  #89
Kotlas's Avatar
Kotlas
Car is a 2002 Z06 with 73,000 miles. Ive driven it hard so some of it comes with the territory, but so far I have experienced:
Coolant reservoir cracked - replaced
Column lock issues - CLB and bypassed relay
Noisy drivetrain - torque tube bearings were bad - replaced bearings and couplers
Oil burning - installed oil catch can
Choppy clutch - bled clutch fluid, works great now
Squeaking belt when cold- installed Gatorback belt from Autozone
Oil sender failed - replaced
Differential leak - still leaking
Random dead battery - replaced with Optima red top, good for the past year
For a car that experiences daily stop-and-go traffic and the weekly hard interstate runs I guess I cant really complain. The car isnt that difficult to work on. Its just that GM dropped the ball in a few places (clutch bleed screw position, column lock, terrible stock shifter).
Old Jan 27, 2011 | 12:11 PM
  #90
white90conv's Avatar
white90conv
2000 with 93K miles. Multifunction switch (cruise control), door control module lock relay, oil pressure sender, fuel tank leak (fixed under warranty), convertible window came loose (glued back in), OEM battery leaked (no major damage), turn signal/flasher relay noisy (not fixed yet), mirrors came loose from sun visors, small differential leak (not fixed), ABS wheel sensor connector came loose (twice), dim HVAC controller. No problems that left me stranded. I am very happy with its reliability. Overall, it is the best car I have ever owned!
Old Jan 27, 2011 | 08:35 PM
  #91
rehirsch8's Avatar
rehirsch8
34K 2004 Coupe. I've had no issues. The car has been drag raced in South Dakota in 90+ degree heat and I've gone to HPDE with no problems.
Old Jan 28, 2011 | 07:42 PM
  #92
vettespur's Avatar
vettespur
one door control module
one tensioner
one battery
thats it, got to love GM quality!
Old Jan 28, 2011 | 08:48 PM
  #93
Jason Squires's Avatar
Jason Squires
Default Right Front ABS Sensor Failed
2001 with 65K miles. When the right front ABS Sensor failed, it was replaced with an entire bearing / hub assembly. Cost more than $1,200 to repair - Ouch !! Had to replace the original battery this past summer - drove it for 10 summers with the original battery.
Old Jan 29, 2011 | 07:33 AM
  #94
rideboy's Avatar
rideboy
5th Gear
2003 vert 130,000 mi no problems since new only 3 sets of tires and 2 batteries plenty of mods 396 hp cammed still drive across country several times a year great car
Old Jan 29, 2011 | 07:51 AM
  #95
VetteDrmr's Avatar
VetteDrmr
I've had only a few significant problems in 220,xxx miles of service. Not going to mention all the wear/consumable items (including pulley and wheel bearings).
The ABS module went out about a year ago; rather than pay the GM $2000 for the part I took a risk on a $300 part off Ebay; works just fine.
Early on I had one electrical gremlin that ended up being a bare wire in the driver door's bundle that was grounding. Since the previous owner had a security system installed I don't know whether it was GM's error or not.
Other than that, nothing comes to mind.
Have a good one,
Mike
Old Jan 29, 2011 | 08:14 AM
  #96
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I haven't had any real mechanical issues in the almost 10 years that I've owned my C-5. However, with only 18,000 miles on it, I shouldn't have.
On the other hand, the driver's side door lock actuator circuit board has had two relays go bad, but fortunately I was able to fix that problem myself. The other issues that C-5s are know for, such as rocking seats, headlight gear failure, steering column lock-up, and rocker arm trunnion failure, have been addressed by myself, in a pre-emptive strike......
Old Jan 29, 2011 | 08:45 AM
  #97
AU N EGL's Avatar
AU N EGL
Same here. Then each later another dead Optima red top. Only reason I keep getting another Optima Red top is they are replaced free on warranty
To C5 Reliability Poll....
Old Jan 29, 2011 | 09:34 AM
  #98
CatCam's Avatar
CatCam
2004 - 9,830 miles.
1 new battery.....that's it.
Old Jan 29, 2011 | 11:03 AM
  #99
hattitude's Avatar
hattitude
ECM / MAF sensor / differential seal / passenger window motor.
All covered by GMPP
Old Jan 29, 2011 | 11:41 AM
  #100
squidnut's Avatar
squidnut
2001 Vert M6 elecrical/semi mechanical issues.
EBCM/rebuilt $220.00
Headlight Motor gears stripped/rebuilt with bronze gears $102.00
Oil Pressure Sender/Current will replace $45.00
Car bought Feb 10 with 39,000 miles. Now has 45,800. Preventative maintenance performed is as follows:
Replaced all fluids, pulled ground connectors from both sides on front frame rails. Disassembles, cleaned and reassembled. Replaced belt checked wires.
