Need a low profile jack
Old Mar 2, 2008 | 10:39 PM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
Default Need a low profile jack
Need to do Exhaust and my car is lowered all the way on the stock bolts and need suggestion for a good floor jack, also can I jack up one side at a time and put it on a jack stand and do the other side?
Old Mar 2, 2008 | 11:15 PM
newberd's Avatar
newberd
Check out Harbor Frieght. This is what I use and I'm lowered as well. Yes you can jack one side, place stands and then go to the other side. I did long tubes a bout 3 weeks ago and had to add shoring under the jack and each stand in a couple of stages to get it up high enough. Its a pita to work from the floor but I had no choice.
Old Mar 2, 2008 | 11:40 PM
wamara's Avatar
wamara
Cruise-In II Veteran
ATD-7325 (google ATD).
Also, this may be the same jack but branded Omega:
http://www.tooltopia.com/index.asp?P...D&ProdID=11737
Northern Tool also sells the Omega for comparison price purposes.
Old Mar 3, 2008 | 12:03 AM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
What about using rhino ramps, they say not to use on all four wheels but it seems safer than jack stands, also dang that is pricey but the 35 Wal-Mart jobs just aren't short enough. It need to be high enough for me to get under but short enough for me to pull the valve covers ETC.
Old Mar 3, 2008 | 12:09 AM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
http://www.harborfreight.com/cpi/cta...emnumber=40105
This might work... 3 1/2 is still too tall but I can pull the fender up to get it under I think. I will have to go outside and measure my cars ride height in the AM
Old Mar 3, 2008 | 01:19 AM
jclarksnakes's Avatar
jclarksnakes
I use an "aluminum racing jack" from Harbor Freight that was $85. SKU #91039. Rated at 3000 lbs. I roll the front tires up onto 15 inch lengths of 2x12 so that the jack with a 25 inch long piece of 2x6 on top of it just pass under the chin spoiler. I could get by without the 2x12s if I was to slide the jack under the car without the 2x6 and then reach under and place the 2x6 on the jack. Be sure to place jack stands under the ends of the 2x6 and to chock the other wheels before you crawl under the car.
Jeff
Old Mar 5, 2008 | 01:47 AM
striper's Avatar
striper
I just made some small ramps out of 2" x 4"s bolt together and cut at an angle. They raise the car 4" and then I can get my jack underneath.
Old Mar 5, 2008 | 08:59 AM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
AC Hydraulics...money well spent!
Old Mar 5, 2008 | 09:35 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I recently bought the Omega jack after my Harbor freight aluminum jack fell apart. I really like the Omega low profile jack as it goes up fast and can even clear the front of the car and make it to the cross member.
Old Mar 5, 2008 | 10:01 AM
SSWEET's Avatar
SSWEET
I purchased a Roush Racing Aluminum Low Profile 3000 lb jack from Sam's Club for about $70-80...Have used it for two years...no problems.
Old Mar 5, 2008 | 03:35 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
SEARS has a really NICE low profile aluminun jack! I have it and its very nice!!
Old Mar 5, 2008 | 07:26 PM
Safedog's Avatar
Safedog
AutoZone.
$99.00 for low profile aluminum jack.
Old Mar 5, 2008 | 10:11 PM
Gideon's_Test's Avatar
Gideon's_Test
Jeff
Another vote for the Harbor Freight low profile jack. I have no problems fitting the jack and pucks under the frame...I plan to lower the car 1/2" but don't think it will be a problem even then, as I have at least a 1/2" clearance now...
Old Mar 5, 2008 | 10:20 PM
AlisonC5's Avatar
AlisonC5
Mines lowered all the way. I roll up on a single 2X12, and then a double 2X12 with angle cut on the end. Finally I can get my ancient Sears giganto floorjack under the front crossmember. If it werent for the stupid air dam, I could get by with the single 2X12s.
Might look into a nice low profile jack one of these days
Andy
Old Mar 5, 2008 | 11:12 PM
JOEY P's Avatar
JOEY P
Walmart sells what they call a racing jack.....Works for me and is only like 50 bucks
Old Mar 5, 2008 | 11:45 PM
ScottGJones's Avatar
ScottGJones
Maybe something like this?
http://www.harborfreight.com/cpi/cta...emnumber=95420
Lift it high enough to put jackstands or rhinos underneath
Old Mar 6, 2008 | 12:46 PM
FASST LN's Avatar
FASST LN
I bought Wal-Mart's "Black Jack" which goes down to 3.5 inches. I think it cost about $30 and has been great.
Sure hard to beat that price and the fact you could pick one up today (no shipping) at the store.
To Need a low profile jack
Old Mar 6, 2008 | 06:00 PM
Oldvetter's Avatar
Oldvetter
I use this one too, it goes down to 3.3 inches, but I paid $60 for mine. It is an extremely heavy, 3 ton jack, commercial quality.
Old Mar 6, 2008 | 07:41 PM
MagneticRed1977's Avatar
MagneticRed1977
Harbor freight has a new low profile jack that is over $120 but looks very nice.
Old Mar 6, 2008 | 08:52 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
but go with 2x6 or 2x8...we do it that way all the time,,,,right z06hellcat?
