Why the heck would anyone buy a component that takes so much effort and $$ to install, buy used? Is the cost savings that great?
I would never buy a used cam.
Originally Posted by Cobra4B
My $0.02 buying critical engine parts used isn't worth the cost savings.
Ya guys really need to blame the seller here, and not the buyer.
There is no problem in re-using a cam, if it's not damaged. This one clearly IS damaged, and that isn't the buyer's fault.
Based on the pics, this localized pitting is the likely result of inadequate heat treating, and anyone who reads over at LS1Tech knows this isn't all that rare of occurance. Both Comp and Cam Motion/Futral have had their fair share of "bad batches" of cams.
As for the peace of mind of buying new....you could buy a brand new cam, and pull it out of your car 5k miles later looking just like this.
Or, you could buy a used cam that's already been run for 5k miles, and still looks like new. Given that comparison, I'd be more apt to trust the used one that's proven to work.
Its not just isolated to one lobe either. You can see the bad lobes in the other picture.
If you put that in your car you can kiss your valvetrain goodbye.
Refer back to our PM's. Its better to save and buy the right parts, then get anxious and buy junk..
I'm sorry you had to learn the hard way. You weren't the first, and you certainly wont be the last..
Many members have purchased used cams and had favorable experiences. most cam companies are charging 50-100 dollars more for their custom grind cams which all usually come from comp cams. the avg used cam goes for $250 whereas new from LG for example they are $450 new. 200 dollars is substantial savings to me.
I'm all about saving money, but not when it comes to internal components of the engine.
now he is trying to get me to claim it at the postal office as damaged in shipping. he swears up and down that it was fine when he shipped it. but i fail to see how that type of scoring could have occured even from dropping it.
I can't believe he said that, that is a felony. Have you posted on LS1Tech? Post those photo's, he will be pressured into returning your money. I couldn't live with myself if I sold someone something like that. Good lord.
You should make sure his %100 trader rating is affected. No way he sold that to you unaware. He's a liar, and if you get a refund, I'll be very surprised.
I'd take that statement made by him to the post office and charge him with fraud on faulty merchandise and using the postal service shipping to do so.
Did you use a credit card to purchase it? If so file a claim with your credit card company.
Good luck
with the rest..How old was that cam? I believe there was a bad batch of cams that was posted on LS1Tech that looked just like that. Severe pitting and it would chew up your lifters....Post pics over there and you will get more info on it..
Yes it is. It is surprising what some people will sell. The cam is induction hardened and has a very thin case, once that is gone-look at your pictures- it just goes down hill. REFUND
Im considering sending him a link to this thread so he can see what just CORVETTE owners are saying.. it should send a pretty clear message. the kid is 20, but even so, I dont think he didnt see this pitting before he shipped it.
Well don't feel bad. I got burned by a CF member on a ls6 intake. The intake was crack the back by the vacuum ports. I could see where the oil had been seeping around the crack. I was out $340 . First time it happened to me.
You have to press the issue, and encourage him to do the same from the vendor he purchased the cam from, even though it means you'll have to send it back to him (Get your $ back first),
if he raises the same complaints about this 5k mi cam to LG...they will hopefully pass the problem on to Comp, and maybe, just maybe he could get his money back too. You can't do that, but he can.
Being vocal almost always nets a resolution. This really isn't LG's fault...all they do is sand the lobe #'s off the end of the cam and put it back in the Comp packaging, but if he bought it new from them, that is his only contact and source of resolution.
Whether or not LG is willing to fight for him and stand by their branded product will remain to be seen.
This cam could be repaired with some slight less lift on that damaged lobe Without even welding, just a slight grind to clean the damage
but
Call comp cams....
This might be salvageable, or they might help you out and give you a new one since they know about these batches..
It wouldnt hurt to give it a try..
If the case hardening is bad, grinding this cam to get down to a clean surface only means you will have the same damage in another 5,000 miles like this one does (If that is the real case here- meaning does it really have only 5k miles or MORE???) I'm assuming the case hardening is too thin and cleaning it up will only make it thinner and more suseptible to repeat damage. Not to mention does your grinder guy have the proper specs to regrind it too... doubtful!!
Send this cam back, (get your money first though ) and start out with a new one. I'm not bashing you about saving money, (I'm cheap) but when it comes to the hassle of putting a Cam in, saving $200 is crazy if you have to open her back up in a year or so.. Whenever!! after you've done all that work, you're going to want it to be right... and stay that way hopefully!! Good luck in getting your cash back!!
