Hardened left output shaft
Old Mar 10, 2008 | 12:51 PM
Lord Vetter's Avatar
Lord Vetter
St. Jude Donor '09-'10-'11-'12-'13
Default Hardened left output shaft
Did a search so if this is a dupe I apologize. Going to be installing a 3.42 Z06 diff in my A4 coupe in April. PN is 12572683. Does anyone know if this comes with the hardened left output shaft? Bought the diff from a GM dealer. Thanks in advance.
Old Mar 10, 2008 | 01:02 PM
vettenuts's Avatar
vettenuts
No, shot peened gears is the major difference I remember.
Old Mar 10, 2008 | 01:09 PM
AU N EGL's Avatar
AU N EGL
Correct.
LPE sells hardened out put shafts. But unless your putting down more then 600 ft lbs of torque they really are not needed.
Old Mar 10, 2008 | 01:21 PM
Lord Vetter
Originally Posted by AU N EGL
Correct.
I'm going to be well south of that number. I have been told that bad wheel hop can also contribute to breaking stock shafts.
Old Mar 10, 2008 | 02:21 PM
RIDE3311's Avatar
RIDE3311
I have heard the same thing. A lot of the guys that are running on slicks or drag radials at the track break output shafts with a lot less than 600rwtq so it really could be wheel hop issues causing the breakage. Wheel hop is worse with drag radials because they have stiffer side walls that don't give. Just my .02.
Old Mar 10, 2008 | 02:58 PM
AU N EGL's Avatar
AU N EGL
Could be driving style too.
LPE has them Rockland Standard has them also.
Old Mar 10, 2008 | 09:03 PM
RIDE3311's Avatar
RIDE3311
Old Mar 11, 2008 | 07:10 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
If I recall, the hardened output shaft was only about another $400.00 when I had the 3:90 gears installed. And I figured, why not.
Old Mar 11, 2008 | 12:18 PM
Mike Mercury's Avatar
Mike Mercury
with the A4, if you don't have a hard-hitting 4000rpm racing converter - using drag radials (which almost makes the car a trailered track-only type car)... it doesn't seem like you could break an output shaft all they easy.
Old Mar 11, 2008 | 12:22 PM
lucky131969's Avatar
lucky131969
Nope.
Old Mar 11, 2008 | 01:07 PM
cyclerage23's Avatar
cyclerage23
Look into the 07-08 Zo6 leftside otput shaft. I heard it was just as good and at times earier to get.
Old Mar 11, 2008 | 04:47 PM
speedsk899's Avatar
speedsk899
I did both sides! Everyone says that the LH shaft is weaker.....but the RH is the side that I have always seen break! By design, the RH is weaker!
Old Apr 4, 2008 | 09:53 PM
salto99's Avatar
salto99
Default Just got my 3.90 done
Tony's Corvette Shop in Gaithersburg MD just finished my 3.42 to 3.90 swap. The dif uses the shot peened gears the heavy duty clutch packs and BOTH output shafts are hardened. The cost for the unit is $2,100. Very well done install and am looking forward to driving many figure eights.
Old Apr 4, 2008 | 09:55 PM
salto99's Avatar
salto99
Default Almost forgot
The 3.90 dif is a Rockland Standard Gear Getrag
To Hardened left output shaft
