Lucky #7
Old Mar 17, 2008 | 07:24 AM
lucky131969's Avatar
lucky131969
Default Lucky #7
I'm in the process of installing a 2001+ intake and decided to not take any chances with old cylinder #7. The crossover pipe for the front fits perfect in the rear.
Old Mar 17, 2008 | 10:13 AM
jedblanks's Avatar
jedblanks
Like you, I didn't want to take any chances, but I also didn't want to spend $60 on two crossover tubes, so I ground the ribs on the intake -- Perfect fit. I just used the pictures on here and didn't even test fit it first. Fell right on the existing 1997 coolant lines
Old Mar 17, 2008 | 10:56 AM
lucky131969
Well....to each their own. I didn't have the heart to grind down a brand new LS6 intake manifold. Considering what I spend on this car anyway, $60 bucks was nothing..not to mention, having everything fit perfectly.
Old Mar 17, 2008 | 11:26 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I will be doing the same mod when I install my FAST 90 and new heads.
Bill
Old Mar 17, 2008 | 11:55 AM
vettenuts's Avatar
vettenuts
I am wondering, once the air is purged, what is the use of the rear cross-over? I wouldn't think enough flow would go through to aid in cooling and if the pump is putting out "X" gpm and you are flow limited at high RPM, and then you divert some flow from the head to the cross-over are you effectively reducing the cooling capability? I am just thinking out loud and wondering what is the better setup?
When I re-fill, I always lift the front of the car, it really helps with air removal.
Old Mar 17, 2008 | 01:57 PM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
O.k. this doesn't make much sense to me. The #7 problem happens on the LS1's and they already a cross over tube with a back to front connect. This is not an LS6 problem.
Old Mar 17, 2008 | 02:30 PM
lucky131969
Do you know of someone who had #7 fail on a pre2001 LS1 with no mods?
Old Mar 26, 2008 | 10:31 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I didnt know one could be installed on the rear.....If Im installing a new forged shortblock, should I go ahead and do this ?
Old Mar 27, 2008 | 06:02 AM
vettenuts's Avatar
vettenuts
I am trying to figure out what it is buying you (I will have mine apart shortly as well) and if someone has definite data that indicates it helps the rear cylinders then I have no problem spending the money. Perhaps Evil-Twin might have input on this subject.
Corvette-Chris, I just saw you lost the motor, sorry to hear that. Didn't you just finish a head/cam installation? What happened?
Old Mar 27, 2008 | 07:51 AM
OhioC5's Avatar
OhioC5
So did you plug the front or use two front pipes? I have an LS-6 intake and tubes but dont have it installed yet. Im unfamaliar with the coolant pipe layout.
Old Mar 27, 2008 | 10:05 AM
Corvette-Chris
St. Jude Donor '08
Yeah, only a couple months ago I finished it. I think the initial tune had alot to do with it and the more I read about my problems from some pretty serious HP junkie here, thats what they suspect also. I think just not enough tuning time the first time I was there and it was going lean up top. It started running worse and worse so I took it back but by that time it was too late. If you would like to know more just shoot me a PM
Old Mar 27, 2008 | 12:58 PM
vettenuts's Avatar
vettenuts
Sorry to hear that, Slowhawk does the tuning on my car and is very cautious of going too lean on the dyno to ensure proper AFR on the street.
Old Mar 27, 2008 | 01:09 PM
frodo84's Avatar
frodo84
Uneducated autodidact
Does anyone know the part number for the crossover pipe? Assuming it can be purchased alone..........thanks.
Old Mar 27, 2008 | 01:20 PM
ZeeOSix's Avatar
ZeeOSix
Can someone point to some background on this issue? Is this all LSx engines? Can Cyl #7 blow out on a bone stock setup, or is it an issue with only highly modified engines?
Old Mar 27, 2008 | 01:34 PM
Corvette-Chris
St. Jude Donor '08
I have read he is awesome and I wish I was a little closer I may need to drive a while to find someone like him because I dont want to take any chances on the new motor
Old Mar 27, 2008 | 01:49 PM
vettenuts's Avatar
vettenuts
There doesn't appear to be a clear answer from everything I have read. Some say tuning and some say cooling. I am taking no chances, I am installed a DeWitts with my new heads and my tuner is very careful to ensure the car isn't lean on the street. Both may be key. Note also that GM tends to run the car rich, which is safer. Also, my tuner showed me just how much difference taking the car from 12.5:1 to 13:1 on the dyno made, I think it was 2 or 3 hp so in my mind its not worth the risk to run the car too lean.
Old Mar 27, 2008 | 01:53 PM
ALVETTE00's Avatar
ALVETTE00
Pardon my stupidity...
I just bought a LS6 manifold and I'm wondering what the issue is with the # 7 piston?
Thanks,
al
To Lucky #7
Old Mar 27, 2008 | 11:18 PM
ALVETTE00's Avatar
ALVETTE00
ttt
Old Mar 28, 2008 | 06:02 AM
vettenuts's Avatar
vettenuts
Thanks,
al
Most who have a problem usually from what I have seen fracture the piston to the top ring land. There are a couple of theories, one is the tune is too lean and the other is that the rear cylinders are not cooled as well and suffer the most.
Old Mar 28, 2008 | 07:24 AM
byte_me's Avatar
byte_me
Originally Posted by lucky131969
I'm in the process of installing an LS6 intake and decided to not take any chances with old cylinder #7. The LS6 crossover pipe for the front fits perfect in the rear.
http://www.flickr.com/photos/1545929...85312/sizes/l/
can you tell us (maybe a dumb question) where you routed the line to and how did it connect at the front?
I like it!
