Lightweight Valves
Old Apr 18, 2008 | 10:40 AM
throwit's Avatar
throwit
Default Lightweight Valves
What are the performance gains from using these?
If a motor is not spinning past 7K, is there a real difference between using SS, Hollow, or TI valves?
Also, should the lightweight valves be used on the Intake, Exhaust or both?
Old Apr 18, 2008 | 11:51 AM
vettenuts's Avatar
vettenuts
Intake is where you will run into problems first due to its larger size. Trade-off is stiffer springs to control heavier parts vs. lower stiffness springs to control lighter parts.
Old Apr 18, 2008 | 01:28 PM
throwit's Avatar
throwit
thx, performance wise, what do you stand to gain?
In theory i would think an engine could rev quicker and higher with lighter valves, but at the same time i would tend to think that rev capabilities are bottlenecked/governed by the weight/friction of the rotating assembly and not necessarily the opening/closing of the valves...
so it seems as though lighter valves are more for reliability/longevity than performance...
am i missing something??
Old Apr 18, 2008 | 01:38 PM
BlackZ06's Avatar
BlackZ06
The weight of the valves really affects only one thing .... the redline (maximum speed) of the engine. As the valves get HEAVIER the top speed goes DOWN. This is due to a little thing called "inertia" ....
Because the intake valves are usually physically larger than the exhaust valves, they are often composed of a different material or other "technology" to try and keep their weight about the same as that of the exhaust valves. You generally want the spring "tension" for all valves to be about the same, especiallly in an engine like a V8 with a single camshaft (like our LSx engines).
The material (technology) used for the valves is determined mainly by the environment they live in ... an intake valve is cooled by the incoming air/fuel mix every time it opens ..... an exhaust valve is heated by the outgoing exhaust gases every time it opens ...... so you will see differences in valve design in one engine just based on that.
Old Apr 18, 2008 | 01:48 PM
throwit's Avatar
throwit
Are you referring to the top speed in each gear? or total top speed of the car?
Also, wouldn't your pistons, rods, & crank be allot more weight to throw around than valves?
Ultimately what I am seeking to understand is what going from hollow stem valves (which are already light), to TI valves would benefit me (or anyone for that matter) from a performance (rwhp/laptime) perspective? and if it would be worth the extra $$ in doing so.
Old Apr 18, 2008 | 01:50 PM
BlackZ06's Avatar
BlackZ06
Yes, all else being equal, an engine revs higher with lighter valves. And yes, the weight/friction/inertia of the rotating assembly is a part of the equation .... BUT .....
In general it is the valve/cam system that is the limiting factor .....
Think of it this way ... in a half revolution of the piston and crankshaft the camshaft and a valve will have to have performed an open/close cycle in a much shorter period of time. If you are an engine designer this is one of the issues you have to look at .... for 180 degrees of rotation in the crankshaft when do you start/end valve opening and closing, and how "high" do the valves have to rise during this period ... and overall what is the limiting factor (redline) for this engine ... the valvetrain or the crankshaft/piston assembly ???
Old Apr 18, 2008 | 02:00 PM
throwit's Avatar
throwit
makes sense...
so hypothetically speaking, if i dont plan on exceeding the ability (redline) of a 100 gram valve, than i do not benefit from going to a 50 gram valve...?? (other than less stress on parts)
ALL else held equal, does lighter valves/softer springs = more rwhp at a given redline, say 6500?
Old Apr 18, 2008 | 02:02 PM
BlackZ06's Avatar
BlackZ06
Are you referring to the top speed in each gear? or total top speed of the car? <---- Top speed in gear .... which theoretically affects "top speed" ..... though for many cars aerodynamics becomes the limiting factor ... not engine speed.
Also, wouldn't your pistons, rods, & crank be allot more weight to throw around than valves? <---- Yeah, but pistons have these really big things called CONNECTING RODS which tend to be easier to control than a valve spring .... but ultimately yes ... thet are a PART of the equation.
Ultimately what I am seeking to understand is what going from hollow stem valves (which are already light), to TI valves would benefit me (or anyone for that matter) from a performance (rwhp/laptime) perspective? and if it would be worth the extra $$ in doing so. <--- see below
First, with many years of working with sales teams ... why didn't I just start by asking "what is your real issue here" ....... I'm a freakin idiot here .....
Switching to a lighter valve, while changing nothing else, is not going to make a wit of difference to your engines performance.
Switching to a lighter valve, while changing nothing else, would only allow you to rev to a higher engine speed (redline) if the maker of the valves can demonstrate that the engines current redline id limited by the valves/springs rather than the rotating mass of the pistons/crankshaft (or you are willing to grenade your engine to determine what parts fail first).
Old Apr 18, 2008 | 02:11 PM
BlackZ06's Avatar
BlackZ06
makes sense...
Correct ... a lighter valve (all else being equal) will not benefit you in any way other than reducing stress in the engine, leading to a longer life (greater reliability).
Lighter valves do not not give you more HP. However, if a lighter valve allows an increase in the engine redline it MIGHT allow for higher horsepower ..... but in a "stock" LSx engine, since the current redline (6,000 for an LS1, 6,500 for an LS6) is already past the engines peak HP output ..... revving higher has little benefit.
Old Apr 18, 2008 | 02:25 PM
throwit's Avatar
throwit
thx BlackZ06, you just saved me some $$
Old Apr 18, 2008 | 09:29 PM
ISeeRed's Avatar
ISeeRed
But the sodium filled valves also promote cooler operation in severe duty applications.......
Old Apr 25, 2008 | 07:29 PM
mathia's Avatar
mathia
Would lighter valves extend valve spring life if everything else (redline, cam profile, etc) stays the same? Or does it not matter as long as your springs are stiff enough to control the valve for a given cam?
Old Apr 25, 2008 | 07:39 PM
AU N EGL's Avatar
AU N EGL
Standard valves are good to 6500, above that the light wt sodium filled valves are needed. light wt valves and better springs are a must for 7000 rpms
Old Apr 25, 2008 | 08:10 PM
blu00rdstr's Avatar
blu00rdstr
Caveat to the no improvement statements above, is; all is currently well with your motor and you're not experiencing valve bounce at any rpm you use now.
Old Apr 25, 2008 | 09:30 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
If the valves are lighter and the springs are not as stiff it would make more power right? yes no
Old Apr 25, 2008 | 09:54 PM
BlackZ06's Avatar
BlackZ06
Interesting point .... you could certainly argue that it would take less energy to rotate the camshaft if you used lighter (less stiff) springs .... but given that you can hand turn the camshaft with the valves/springs in place ..... I just can't see that you'd get ... say ... maybe a 1/10th of a HP .... I don't know .... MAYBE a 1/4 HP tops ??? The camshaft, to me, turns pretty easily .... I'd be intrigued if someone has ever been able to measure the difference just by changing springs.
When the Z06 got the lighter valves and gained 20 HP, GM Powertrain attributed the 20 HP to things like the different cam profile, elimination of the pup cats, de-screened MAF ...... I've never seen anything that said that any of that 20 HP came because of the springs/valves.
GM Powertrain said the only reason that they went to the new valve/spring combination was because the cam had a higher lift and a "faster" opening speed for the valves, requiring lighter valves ... which allowed for "weaker" springs.
Old Apr 26, 2008 | 02:42 AM
ISeeRed's Avatar
ISeeRed
Tighter springs control the valves. When springs are opening, springs are closing, so it's a wash. The tension on both sides make it virtually the same tension wise. There have been exhaustive studies on this. The big thing is to make sure you have enough spring to control your valves with your cam profile. Float = bad!
Old Apr 26, 2008 | 07:29 AM
AU N EGL's Avatar
AU N EGL
One of the challenges with normal valves and springs above 6500 is valve float.
Your engine may spin to 7000 rpms but there is little if any additional power past 6500. Which is still not a bad thing, as shifting at 1500 rpms above peak HP is desirable, so that when you do shift, the the rpms drop into that sweet spot.
One of the items too look for is an intimidate drop, or hick-up on the hp line on a dyno chart. this may be an indication of valve float.
To Lightweight Valves
