I've got my cam in now and the timing gear and crank gear dots lined up. Seems to be more slack in the timing chain than I would expect. The car has 40k miles. I aquired it from a 78 year old man you took very good care of it at 30k mikes. I've never really driven the car hard and I know that the previous owner didn't as well. Is a "fair" amount of slack normal?
The dots look to be aligned up perfectly. Is there any "gotchas" here that I should be aware of. I don't know why I'm stessing so much on this, I've done this numerous times on my old '71 chevelle. Maybe because I was young and stupid and didn't care.
I'm doing the same install plus a few more things. I up-graded to an LS2 timing chain and intended to install a damper. Knowing that I had to drill and tap the block, I was willing to take that project on. When I removed the cover, I saw that GM did the drilling and tapping for me!
Here is the damper installed:
I got the damper from Gene Culley:
Don't forget to use RED high strength lock tight on the cam retainer bolts and cam bolts and make sure that you clearance your Oil Pump using 0.002" - 0.003" feeler gages or shim stock around the crank drive hub.
Oh,,,,yea,,,,you should CHECK CHECK and DOUBLE CHECK your timing marks! After i posted that picture, i said "self,,,that looks FUBAR. Went out and rechecked and sure as hell, I was ONE tooth off. Its fixed NOW!
I also turned the can gear all the way to one side to take all the slack out of the chain to show you how much slack is on the other side on a new LS2 chain.
Here is a picture of the old LS-1/6 timing chain compared to the LS2:
Bill did you use an LS6 dampener or an LS2 dampener? I have an 04 LS6 block in my 99, and I'm thinking about stabbing a different cam in my stroker. While it is apart I wanted to swap my TSP pump for a Melling, and a dampener was something I thought about. I have the holes there, but I think an LS6 dampener was significantly more than an LS2 dampener?
The LS1/6 timing chain damper is tan in color and has a 2.187" bolt center. The LS2 timing chain damper is black in color and has a 1.762" bolt center. Unfortunately, some of the '04 LS1/6 blocks were drilled for the narrower LS2 bolt center so the only way to know which is correct is to measure. You should hope it's drilled for the narrower bolt center due to the lower cost of the LS2 damper. The '07 LS2 motors have an even newer timing chain damper that fits the narrow LS2 bolt centers, see below:
Mine is an LS6 tan damper and yes it was expensive as is everything else in this project!
I hope the HP/TQ increase increases as much as the price of this project!
