I having electrical problems
Old Apr 26, 2008 | 09:53 PM
Kamil D.'s Avatar
Kamil D.
Default I having electrical problems
I having electrical problems the lights are dimming and every electronic display also when I check to power on the DIC it under 13 usually 12,5 and jumps down. I did drained the battery one, but I don think it has to do with that also when I start the car the DIC will tell me like above 13 then I drive fore some time and I drops. What should I check ?
Old Apr 26, 2008 | 11:26 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
PM Bill Curlee, he can help you
Old Apr 26, 2008 | 11:31 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Check the battery connections.
Old Apr 26, 2008 | 11:51 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Check the alternator output. If it has good voltage, then check the battery voltage. If it is low, then check continuity in between and check all connections in between.
Old Apr 27, 2008 | 12:09 AM
LV,99LS1VERT's Avatar
LV,99LS1VERT
Old Apr 27, 2008 | 10:03 AM
aquaholic's Avatar
aquaholic
what year is the car? how old is the battery?
Old Apr 27, 2008 | 12:42 PM
Kamil D.'s Avatar
Kamil D.
car is 97 the battery i dont know but it looks newer like 2-3 years
Old Apr 27, 2008 | 01:32 PM
RIDE3311's Avatar
RIDE3311
If you don't have an amp/volt meter to check the alternator output and battery voltage just take it by a local Autozone or any auto parts store and they will usually check it for free! Good luck
Old Apr 27, 2008 | 01:40 PM
Kamil D.'s Avatar
Kamil D.
what is the AMP/voltage that i should get ?
Old Apr 27, 2008 | 09:29 PM
dgrant3830's Avatar
dgrant3830
With the engine off, you should see a solid 12.5 volts on the battery. With the engine running you should see 13.8 to 14.3. Changing loads such as turning on the lights and off again, you should see the voltage change a little then recover right away.
Old Apr 27, 2008 | 10:43 PM
Kamil D.'s Avatar
Kamil D.
with the car running im under 13
Old Apr 27, 2008 | 11:02 PM
zr2lang's Avatar
zr2lang
Default Try this for your electrical issues
Bill, Wow what a weekend I had finding my electrical issue. I basically went through every ground and removed my aftermarket alarm system that was installed on the car before I bought it. That all still didn't work. I read your thread about the ignition contacts having burnt carbon on them. Well what do you think I found. I took my dash apart and removed the ignition. I took the green connector off and found that all of the contact had burnt carbon on them. I took my dremel tool and clean them. Put everything back together and the dreaded electrical issue are GONE!!!!!. Well i ques now that my grounds are clean and the ignition switch is clean as well.
Thanks for all of your hard work on all of these threads. I couldn't of figured it out for people like yourself and others on the forum.
Thanks again
Old Apr 27, 2008 | 11:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Kimil
Man,,,,,,,,,,,,,,,owning a 97,,,,,,,,,,,,,,,,you most likely have LOTs to do to solve your electrical issues. Your car is 11+ years old and some of the grounds are most likely compromised. I have a post that you probably take a look at. It explains a lot about common electrical issues. If you service your grounds,,,,make SURE you soak them over night in some sort of penetrating oil. Even then,,they might ring off when you remove them for cleaning/inspection. If they do,,,just repalce the stud witha self tapping sheet metal screw.
Here are some of the things that may be causing you electrical issues :
1. Chassis Grounds. Examine each one and clean them.
2. Battery Connections. Clean the connections and MAKE SURE that you torque the battery terminals to 11 FT /LBS
3. Examine your STARTER solenoid connections. They can and do work loose. Your alternator charging circuit goes THROUGH the solenoid connections. They MUST be tight, clean and in good condition.
Examine the connection on the back of the alternator. It MUST be clean and tight.
4. Battery condition. Have your battery tested and make sure that its in good shape.
5. Ignition switch> As our cars age, electrical switches will start to fail. The ignition switch is one that will sooner or later. I will be cleaning mine SOON! I have a post on how to clean it for FREEEEEE
Dont get me wrong. Theres NOTHING wrong with a 97. Its just aged more than the other C5s and will need some extra attention.
BC
Old Apr 29, 2008 | 12:20 PM
Kamil D.'s Avatar
Kamil D.
Originally Posted by Bill Curlee
Kimil
BC
bill I’m gone clean the grounds *** sun as I can but how would you explain that the voltage starts to drop after 4-5 minutes of driving,
start up it tells me 9 V then in a second it jumps to 14 I drive it fore 4-5 minutes and then I get the lights dimming and 11-12.5 V also on startup I started getting a noise like its coming from the drive belt.
so far I check my connection to the battery and alternator and they are perfect can you plays help my I want to put HID and some other things in the car and I want to fixed this problem first.
also at the same time that I started to get the V drop I put in the harness bypass because of the LED DRL I put in this is the post for that,
and also my head lights will not come on if I have the driving lights on I have to turn them off and the turn the **** feast then they come on
http://forums.corvetteforum.com/show....php?t=1995689
is it possible fore the harness to be doing this ?
Old Apr 29, 2008 | 12:55 PM
bestvettever's Avatar
bestvettever
Default Assumes a good battery
One thing that must be checked and not assumed is the battery condition. It may be something else, but you must confirm that the battery is good before running in circles. A heavily sulphated battery will act like a full battery to the charging circuit, even though it will not take a full charge. When the reg reads the battery acting like it is full it cuts down the charging rate, which could explain the rate coming down after a few minutes of driving. Do a load test on it to determine if it is in fact good, and look under it under the tray to make sure you did not have a previous acid leak reak havoc with your electronics, after you confirm the battery as good then you can move on to what has been posted.
Good Luck.
Old Apr 29, 2008 | 01:07 PM
Kamil D.'s Avatar
Kamil D.
Good Luck.
gone do that today
Old Apr 29, 2008 | 01:15 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Good Luck.
READ #4 in my recommendations! Remove the battery, take it in to a service center that can load test a battery and determine if it is good or bad!
C5s and C6s DO NOT tollerate low voltage very well. It causes all sorts of strange issues. The issues will be different in different cars with the exact same bad battery.
Until you determine the battery condition,,,were just guessing. If your seeing 9 volts at start up, that battery is TOAST!
Remember! Battery voltage is inversly porportional to battery current. When the starter pulls 300-400 amps out of the battery, battery voltage will go low. If the battery cant supply enough voltage ( 9 VDC ) STRANGE THINGS WILL HAPPEN!
BC
To I having electrical problems
Old Apr 29, 2008 | 01:57 PM
Kamil D.'s Avatar
Kamil D.
BC
you right, and thank you fore the time your taking to help my, if I need a new battery what should I buy
Old Apr 29, 2008 | 02:16 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I would get a standard lead acid battery. WALMart batteries works well. You can purchase THREE walmart batteries for the price of ONE OPTIMA!
The OPTIMAs work well but are EXPENSIVE! I have a red top and the first one failed with in 6 Mo. This one (the other one was replaced under the OPTIMA warranty) is going on its 5th year and is just starting to signs of needing replacement.
Old Apr 29, 2008 | 02:33 PM
Kamil D.'s Avatar
Kamil D.
I’m sorry but can you specify on what kind of battery I need like model # or what should I look fore
