DOT 5 Reversal Help
Old May 4, 2008 | 11:21 PM
coneracer01's Avatar
coneracer01
Navigator
Default DOT 5 Reversal Help
Long story, here is a summary: I made my first major blunder with my C5 after 7 years of ownership, I introduced DOT 5 into the brake system.
Next Question: How to get it out? One suggestion was to bleed the system with denatured alcohol to clean the silicone from the lines. While in theory it sounds like it will work, it may make my problem worse. I am open for suggestions and I am already looking into what it will cost to replace the system as a worst case scenario. Thanks for you help and yes I already know I am an idiot so be kind.
Old May 4, 2008 | 11:34 PM
chuckster's Avatar
chuckster
Was it truly DOT 5? or was it 5.1? 5.1 is actually ok and is not Silicone based.. Just in case this is a false alarm.
Old May 5, 2008 | 05:30 AM
vettenuts's Avatar
vettenuts
Define "introduced". Is it in the master cylinder only or throughout the brake system?
Old May 5, 2008 | 07:51 AM
AU N EGL's Avatar
AU N EGL
Do a full brake system flush a few times.
Take a turkey baster and get the DOT5 chit out of the MC. Put in some DOT 4 Castrol LMA or Valvoine Syntech into the MC and bleed and bleed.
Dont let the MC run dry and you will need a MOTIVE POWER BLEEDER or a Tech II to open up the ABS system.
Do a full bleed and go for an easy drive and do a few easy stops, then put your car back on jack stands and do a FULL brake system flush again.
Good Luck
Old May 5, 2008 | 10:47 PM
coneracer01
Navigator
Introduced means I went the whole way and bled the DOT 5 Silicone stuff through the whole system. The ABS module is my main concern with the calipers a close second. I worry that I will just never get the stuff completely out of the system without rebuilding the brake system and it may cause some issues while Autocrossing or track driving. I only put it in because it was all I could find locally (at a performance shop no less) that had a high wet boiling point. I quickly learned afterwards of my mistake. I am running a couple track days and the car was in bad need of a bleed (original fluid). I will obviously try some of the fluid mentioned in other posts but first I will bleed the snot out of it with cheaper stuff. I have two months before the first track driving event. I will try the cheap bleed first and then more drastic later if necessary. Still open to other suggestions. I am also bothering a few GM guys I know.
Old May 5, 2008 | 11:04 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You can activate the ABS without a TechII by simply spinning the wheels, but whether it will do it enough to clean it out is another matter. If it was me, I would have it to either a dealer or a professional brake shop right away.
Old May 5, 2008 | 11:38 PM
coneracer01
Navigator
I finally found the right procedure in my service manual. They recommend disassembling and cleaning with denatured alcohol. They say to clean the master cylinder, replace all the rubber hoses, rebuild the calipers with new rubber and replace the ABS modulator valve. Sounds easy and cheap, crap! At least the one thought of bleeding with denatured alcohol was right, sort of. Well, live and learn, hopefully from someone elses mistakes next time.
Old May 5, 2008 | 11:42 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Sounds like you will need a Tech II for that procedure.
Old May 6, 2008 | 03:23 AM
dieseldave56's Avatar
dieseldave56
Default DOT 5 removal
I replaced the DOT4 in my Trans AM with DOT 5 for a long term storage (16 years). In order to get all the DOT5 out you will need to remove the brake componets and replace the brake lines. DOT 4 and DOT 5 are not compatible. Denatured alochol or brake cleaner worked for me.
Old May 6, 2008 | 05:30 AM
vettenuts's Avatar
vettenuts
I rebuilt my calipers after powder coating, the GM kits are excellent for this purpose.
Hope everything comes out OK.
Old May 6, 2008 | 08:08 PM
coneracer01
Navigator
Thanks everybody, I appreciate the support. I at least feel like I am headed the right direction. Now I just have to do it or find a shop I can trust to complete the job right. Anyone know a good shop in the Detroit/Lansing Michigan area. I am not sure I trust a dealer to complete it properly.
Old May 6, 2008 | 08:56 PM
Bill Dearborn's Avatar
Bill Dearborn
The ABS modulator valve will not be cheap unless you can get a good used unit from a forum used parts vendor.
Bill
To DOT 5 Reversal Help
