What is normal oil temp?
Old Jun 6, 2008 | 07:46 AM
LDB C5's Avatar
LDB C5
Default What is normal oil temp?
What is everyone seeing for oil temp. On the highway mine varies from ~ 208 - 215. Is this normal? high?
Old Jun 6, 2008 | 08:04 AM
vettenuts's Avatar
vettenuts
That's right about where mine is as well.
Old Jun 6, 2008 | 08:47 AM
VetteDrmr's Avatar
VetteDrmr
You're right in the sweet spot. LSx engines are designed for oil temps between 190-240 degrees (although you'll rarely if ever see temps that high in normal street driving).
Autocross and road racing will push temps into the high 200s, esp. down here in TX.
HTH, and have a good one,
Mike
Old Jun 6, 2008 | 09:36 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Old Jun 6, 2008 | 09:40 AM
DPG's Avatar
DPG
St. Jude Donor '06
Len on the highway im seeing the same temps, the faster i drive the higher the temp goes. keep on truckin buddy
Old Jun 6, 2008 | 09:46 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Len, that is about right Ambient temp plays a big part as you know... my temps are a tad lower, but I know you are running higher compression ratio and more HP so that makes sense. On the trip to bowling green, temp outside was about 82 and at cruise around 70mph I was running about 201-205 give or take a few degrees/rpm's
Old Jun 6, 2008 | 09:59 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Coolant temperature also affects the oil temperature. I usually see my
oil temp. running 10-15 degees higher than the coolant.
Old Jun 6, 2008 | 12:26 PM
LDB C5's Avatar
LDB C5
Thanks for the info My coolant tends to stay right around 200.
Old Jun 6, 2008 | 01:17 PM
Quicksilver Vert 01
Your oil temp.is right where it should be.
To What is normal oil temp?
