"Reduced Engine Power"
Old Jun 9, 2008 | 02:14 PM
Hayabusian's Avatar
Hayabusian
Cruising
Yeah Well I guess I cursed myself! I thought everything was good to go, apparently it is not. Here are the current codes I know one is the TPS but I cant find a couple of them.
P 1221 H
P 1571 H
C 1278 H
U 1064 H
I looked for the current or "c" code but none displayed
Old Jun 9, 2008 | 03:53 PM
gray-c5's Avatar
gray-c5
St. Jude Donor '08
Default 17113566
I have simular problems and I'm ordering a new throttle position sensor for my 2004. I think the part number is 17113566. At least that's what I ordered. If what I was told is correct, that is good for 2001 - 2004. Good luck and I know what the "reduced power" feels like.
Old Jun 9, 2008 | 04:12 PM
Hayabusian's Avatar
Hayabusian
Cruising
Yeah, Its terrible. I was supposed to take it on vacation friday. I dont really have a warm fuzzy fealing about that. But I dont wanna be reduced to driving a Dodge.
Old Jun 10, 2008 | 10:33 PM
BlackZ06's Avatar
BlackZ06
P 1221 H - Throttle Position Sensor
P 1571 H - Traction Control Requested Torque
C 1278 H - TCS Tmporarily Inhibited By PCM
U 1064 H
You're back to the same ones .... sure sounds like the Throttle Position Sensors (P1221), and that is causing the other two to set.
You can order the sensors from either of these sites ... the dealer list price for the sensor is $133.49 and it is part number 17113566 and it fits all C5 Corvettes ... 1997 through 2004.
http://www.gmpartsdirect.com
http://www.gmpartshouse.com
That should cure it.
