Nitrogen in tires
Old Jun 14, 2008 | 10:37 PM
PilotAce2112's Avatar
PilotAce2112
Default Nitrogen in tires
I recently had my tires rotated and had the guys remove the air and put in nitrogen. It rides better and the pressure doesnt increase on trips as it did. Anyone having any technical issue with Nitrogen in the tires that I am not aware of?? Thanks
Old Jun 14, 2008 | 11:22 PM
my6thvette's Avatar
my6thvette
I filled my tires with nitrous oxide and gained 150 HP.
Old Jun 14, 2008 | 11:46 PM
Barry Hanna's Avatar
Barry Hanna
Default Nitrogen
It's OK, but regular air is 78% nitrogen so I don't think it's that important to go to 100% unless you are racing or concerned about unusual wheel corosion. It is true that since nitrogen has a higher molal weight it won't bleed off or change pressure with temperature variation as much as regular air, but I cannot imagine the difference to be worth the trouble.
Old Jun 15, 2008 | 12:17 AM
Higgs Boson's Avatar
Higgs Boson
Nitrogen is a gas just like air. In a completely sealed environment the pressure will still go up or down with temp changes. Worthless.
Old Jun 15, 2008 | 02:13 AM
Fred Linden's Avatar
Fred Linden
Default A Recent Note About Nitrogen
Just got a flyer from Costco that has a section re tires. They apparently use nitrogen to inflate tires instead of compressed air. They are saying tires inflated with compressed air lose 1 to 2 psi of inflation pressure per month. This (according to Costco) is because"oxygen molecules in air "migrate" out of tires. Nitrogen molecules migrate out of tires 300 to 400% more slowly than O2 molecules." We're really splitting hairs here I think.
Old Jun 15, 2008 | 02:34 AM
97C5owner's Avatar
97C5owner
AWESOME!! My shop sells it.... but i put on the same shelf as snake oil. Ambient air is appx 70+% nitrogen anyway. It expands with heat like ambient air. End result... Like changing out winter air for summer air in the tires!!!
Old Jun 15, 2008 | 03:24 AM
LoneStarFRC's Avatar
LoneStarFRC
I would use it all the time if I could find it everywhere; problem is, it's not so.....
Old Jun 15, 2008 | 07:11 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Like many marketing ploys, nitrogen for tires was design to make you think that the tire dealer with it offers you something better then any other so you will buy from them. It's that simple, and it works.
The only real advantage the nitrogen offers is less corrosive and less moisture. But any good tire shop that had a clean dry air source is giving you about the same advantage.
Some will tell you that “aircraft tires use nitrogen so it has to be good”, but like many things, the primary reason aircraft use it is due to the high psi the tires run and the volume of gas the tires need. Many have well over 100 + psi in them, and are serviced from 3000 + psi bottles.
One other thing I get a chuckle from is the question of what percentage of the tire filled with nitrogen? They never quote the percentage and they would have to evacuate the tire and purge it a number of times to get near 100 percent, which they never say.
Regards,
Eric D
Old Jun 15, 2008 | 09:44 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Try filling your tires with helium next time.
It will reduce your unsprung weight.
Old Jun 15, 2008 | 11:22 AM
C5SCCA's Avatar
C5SCCA
Nitrogen in a tire has a purpose. Stock car tires are filled with nitrogen because their expansion rates are more precisely defined due to the lack of moisture content. For a street application, does it matter? Check your tires and refill with air as necessary. If you are a highly competitive race team, you are already using it.
Old Jun 15, 2008 | 11:27 AM
robert123's Avatar
robert123
I think its a better mod than a hood seal.
Old Jun 15, 2008 | 01:00 PM
thetaxman's Avatar
thetaxman
it's a complete waste of time for street cars
as far as it
rides better
Old Jun 15, 2008 | 01:27 PM
jrose7004's Avatar
jrose7004
It's all in your mind about it riding better!
Old Jun 15, 2008 | 01:37 PM
my6thvette's Avatar
my6thvette
For those looking for a technical discussion concerning the ability of nitrogen and oxygen to permeate through rubber tires, you might want to read this.
http://www.getnitrogen.org/pdf/graham.pdf
According to this article, oxygen will pass through the tire at a rate 3-4 times that of nitrogen. However, what the article doesn't say is that air is primarily nitrogen and, with time, this will tend to further concentrate the nitrogen through loss of oxygen through the tire walls. Sounds like nitrogen is not a bad idea but probably not worth the effort.
Old Jun 15, 2008 | 03:11 PM
vettenuts's Avatar
vettenuts
Place I buy my tires from fills with it, no problems and no extra charge so why not.
Old Jun 15, 2008 | 04:20 PM
thetaxman's Avatar
thetaxman
it won't hurt anything
but
it realy doesn't help either
Old Jun 15, 2008 | 05:17 PM
Boodieman's Avatar
Boodieman
The biggest gain from using 100% nitrogen is the resistance you get from corrosion to your steel cables in your belts in the tire's summit.
I'm not certain if nitrogen permeates slower than oxygen thru tires, but I do know oxygen does make its way slowly to the steel belts. Now, those steel cables are lightly coated w/ brass to enable adhesion to the rubber skim, but the ends of the cables, where the steel belt tissue is cut at the factory, are not.
Keeping oxygen away from that area helps considerably in tire durability.
I've never heard of any improvement in ride comfort when using 100% nitrogen. And if you have "zero pressure" or "run flat" tires on your car, those tire's sidewall's are so "stiff" that changing gas won't make any difference in ride quality.
To Nitrogen in tires
Old Jun 15, 2008 | 10:56 PM
thetaxman's Avatar
thetaxman
Old Jun 15, 2008 | 11:15 PM
Higgs Boson
Yep I need to protect my belts in my radials from O2 since I go through tires every 45 years.....
Old Jun 15, 2008 | 11:23 PM
lucky131969's Avatar
lucky131969
So you noticed a better ride with nitrogen as opposed to air? So how exactly does that work? How does nitrogen change the composition of the tires to make it ride better?
Also, how do you rotate directional wheels of different sizes?
