Nitrogen in tires
Old Jun 16, 2008 | 12:45 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Nitrogen shields the FLUX CAPACITOR from Oxygen thus the inorganic ion field is greater making Plutonium Naborg more readily available to the staraforic stabilizer. That my friend is the key secret to more HP!
BC ( I think)
Old Jun 16, 2008 | 12:46 AM
2KFRC5's Avatar
2KFRC5
http://www.gmfleet.com/pdf/TechTip_0...itrogenGas.pdf
Old Jun 16, 2008 | 03:22 AM
DefenderC5's Avatar
DefenderC5
Originally Posted by PilotAce2112
I recently had my tires rotated and had the guys remove the air and put in nitrogen. It rides better and the pressure doesnt increase on trips as it did. Anyone having any technical issue with Nitrogen in the tires that I am not aware of?? Thanks
I think you believe it rides better, but in actuality it rides exactly the same.
Unless they are sucking all the air OUT with a vacuum of the tire before refilling it, it still isn't "100% Nitrogen". Letting the air out and refilling it does not remove the air completely.
Even if it was, you wouldn't notice a difference over 78% nitrogen regular air.
Big Brand Tire tried to sell it to me and said that I should put it in my car because "Nascar does it". I told him when I'm driving 200 mph to work, I will consider it. I'd put it in my tires if it were free, but if they are charging for it... it is a sales gimmick.
Old Jun 16, 2008 | 06:45 AM
thetaxman's Avatar
thetaxman
if you keep tires THAT long, they will be junk anyway
Seriously, it's usless for street
Old Jun 16, 2008 | 08:17 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Rotated???
Old Jun 16, 2008 | 08:40 AM
bucwheat's Avatar
bucwheat
How do you rotate vette tires?
Old Jun 16, 2008 | 09:01 AM
AU N EGL's Avatar
AU N EGL
Drive your vette. the tires rotate around and around
Old Jun 16, 2008 | 12:29 PM
danman_s's Avatar
danman_s
Right to left and left to right.
Old Jun 16, 2008 | 12:50 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
It's possible that the tires PilotAce2112 has are non directional.
In that case,they could be switched RR to LR and RF to LF.
Old Jun 16, 2008 | 09:45 PM
2KFRC5's Avatar
2KFRC5
????????????? How long, what ?
Am I missing something ?
Old Jun 16, 2008 | 11:05 PM
peebee_c5's Avatar
peebee_c5
Until they rust from using air rather than nitrogen, all that O2 and water rusting the belts. Knocks at least 10 years off of what should be a 50 year tire. I use Zaino Z-16 tire gloss to remove the rust and extend the life for a couple extra years, can't justify the cost of N2.
Old Jun 16, 2008 | 11:28 PM
thetaxman's Avatar
thetaxman
read the complete pdf
Old Jun 17, 2008 | 12:06 AM
  #33
2KFRC5's Avatar
2KFRC5
Aww crap, I gotta read it?
Well, my last blow-out was due to the steel strands rusting through on one of my Michelins. Good thing it was a dually, or I couldda been kilt.
Anyway, I wasn't reading long life into the tire, just posting what GM had to say about the use of nitrogen. And I do think there is no advantage, or nothing negative about its use, provided it's free, in normal street use.
Old Jun 17, 2008 | 12:41 AM
  #34
thetaxman's Avatar
thetaxman
correct, if it's free , it's worth it
