Oil Change
Old Jul 14, 2008 | 12:51 AM
striper's Avatar
striper
I've always used Mobil 1 but on the last change I tried Royal Purple. I've noticed absolutely no difference but it was accessible, also sold at Walmart. I haven't decided on which I'll use next time. For filter, I either use AC or the NAPA Gold. I usually change when the indicator gets to 50% or lower. My car never uses a drop between changes. When jacking the car up it is recommended to have the back higher than the front to get a proper drain. You can also fill the filter with oil before you install it.
