Had a leak as well same area ,it ended up being my Oil pressure sending unit, it had went bad and oil was coming up through it and leaking down the backside of the engine, hope this helps.
Originally Posted by Chrisdann1
It also seems to be red in colour.
Chris stated it was red in color, was yours red????
I am sorry if I offended you, not my intention, nor was it meant to be a smart azz response. I thought maybe I had missed something that you may have known about. I know that some folks will put in oils other then Mobil One. My first thought after your post, maybe he or someone before him put in oil that was red in color. That might explain the leak from the oil pressure sending unit and the color.
