LS2 timing chain vs. stock
Old Jul 22, 2008 | 09:12 PM
Bigstik's Avatar
Bigstik
Default LS2 timing chain vs. stock
What is the benefit of installing the LS2 timing chain over the stock LS6 chain?
Thanks in advance.
Nick
Old Jul 22, 2008 | 09:18 PM
CYA-Vett's Avatar
CYA-Vett
Depends on what else your are intalling at the time and if you have access to it...
Old Jul 22, 2008 | 09:24 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Side plates of the chain are much thicker, making it stronger.
The "LS2" chain is now the stock replacement for all LSx engines...f you go to a dealer and ask for a LS6 chain, you will get the LS2.
Just a normal part revision, for the better.
Old Jul 23, 2008 | 08:34 AM
Bigstik's Avatar
Bigstik
So when installing an aftermarket cam, the only real benefit to putting the LS2 chain on is preventative measures.
Old Jul 23, 2008 | 09:28 AM
CYA-Vett's Avatar
CYA-Vett
Yes and no...basically to replace a timing chain in the future requires the same amount of work as a cam swap, since your car will already be apart it costs nothingto replace...except the cost of the part...The same applies for an underdrive pulley. Will the stock chain break? Probably not, will the upgraded chain break? No...Do yourself a favor and change it...If your looking to save money, swap the chain and keep the stock push rods.
Old Jul 23, 2008 | 09:31 AM
Bigstik's Avatar
Bigstik
Keep the stock push rods......really. I have always heard of getting aftermarkets. But maybe that is just with an extremely wild cam.
Old Jul 23, 2008 | 09:32 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have a comparsion picture of a stock and LS2 chain in my files. I will post it later tonight. Up grading to an LS2 chain is a NO Brainer if your already in the engine for MODS. If your just ripping it apart to change the chain,,,,thats a LOT of work and most likely NOT required.
BC
Old Jul 23, 2008 | 09:46 AM
J.R.'s Avatar
J.R.
BC
https://www.corvetteforum.com/forums...ies/iagree.gif
Old Jul 23, 2008 | 10:42 AM
CYA-Vett's Avatar
CYA-Vett
Well I've had 5 cams in my C5, small to huge, I never, nor have any of my friends ever bent a stock rod. We all race our cars too. I had a T Rex cam which is about the biggest cam anyone would ever consider, no problems...if a rod bends so what...if a timing chain breaks $$$
Old Jul 23, 2008 | 10:48 AM
Bigstik's Avatar
Bigstik
Well that will save a few $$. Thanks for the advice.
Old Jul 23, 2008 | 11:21 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
As others have said the LS2 timing chain is a lot stronger than the LS1 chain. My car is getting new heads and cam as we speak. My brother (AJG1915) is spinning the wrenches.
He told me that the chain (LS1) in my car (99 FRC) with about 41K miles was pretty darn loose. Loose enough in fact to screw up the cam gear so we have to buy another.
It just makes good sense if you are there doing a cam to invest in a good timing chain like the LS2. Since I go a little overboard ( I think my brother is rubbing off on me ) I went with a Katech C5R timing chain.
Appreciate the tip about the pushrods. Been going back and forth on that one.
Old Jul 23, 2008 | 11:26 AM
black98c5's Avatar
black98c5
The LS2 timing chain is inexpensive and a lot beefier. I had one installed when the cam went in.
Old Jul 23, 2008 | 11:52 AM
Rob's 73's Avatar
Rob's 73
I went with a rollmaster double after my LS2 chain broke!
Old Jul 23, 2008 | 04:48 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Heres the comparison pic that I promised:
If your block has the machined holes to accept a chain damper,,,I strongly recommend installing it:
BC
Old Jul 23, 2008 | 06:01 PM
RC45's Avatar
RC45
I went with a rollmaster double as an upgrade to my LS6 chain, then went to an LS2 chain when rollmaster double broke, then went with a Katech C5R chain when the LS2 broke
Old Jul 23, 2008 | 06:08 PM
Sinister-one's Avatar
Sinister-one
Have a brand new Rollmaster waiting to be installed with my new LG cam !
Old Jul 23, 2008 | 06:49 PM
vettenuts's Avatar
vettenuts
That's my route too, but I am waiting for the Cloyes Hex-Adjust with the Torrington bearing, should be out any time now (per Mike at Cloyes). Katech chain will go on the Cloyes sprockets.
To LS2 timing chain vs. stock
Old Jul 24, 2008 | 08:56 AM
Bigstik's Avatar
Bigstik
What do you have to do to break the LS2 chain and the double chain? Please let me know so I don't do it.
Old Jul 24, 2008 | 09:38 AM
jedblanks's Avatar
jedblanks
I think the implication here is:
If you miss a shift with stock pushrods, you bend pushrods.
If you miss a shift with hardened pushrods you stress/stretch/break the chain.
Old Jul 24, 2008 | 03:51 PM
RC45's Avatar
RC45
Neither of my chain snaps were missed shift, both snapped under load of throttle pedal revs.
The double roller snapped during an "encounter with a blown GTO" on the freeway - and the LS2 snapped on a throttle blip before a shift on the road course.
I just know that stuff breaks if you push it hard enough...
