I am looking to do a cam install this fall and wanted to make sure that I have a good comprehensive list of parts needs for the engine to run properly. Here is what I have;
Cam (looking at the G5x3)
Springs
Retainers
Seats
Seals
Injectors (SVO #30)
Timing chain (While I have it apart anyway)
From post
POrted oil pump
Lifters
Underdrive pulley
Timing cover gaskets with Water pump gaskets
arp balancer bolt
Timing chain dampener
I am sure that I am missing something and I know I will think of it later, but I just don't want to have to run out and buy something last minute during the install. Also, if anyone has any of these parts for sale, shoot me a pm.
Man.....there is a lot more crap involved than I orginally thought. Which is exactly why i posted this. To make sure that I had everything I needed to begin with. I am sure something will come up, but this is helping a lot.
a new water pump will depend on mileage. You usually won't need it, but you will need the gasket set. Just get the set that has the water pump and timing cover together.
and yes i was in the same boat as you but i didnt prepare as well as you are getting a UD damper is a good idea too.
My car didn't have a harmonic balancer when I did my swap...is that a bad thing?
If your engine was running before you did the swap,,,,you had a harmonic balancer. You would have to because thats what drives the belt that turns all the pulleys I thingkwhat you mean is,,,it didn't have a timing chain dampener:
Like this chain dampener:
Engines before 2004 were suppose to NOT have them. Some 2002 and 2003 blocks were machined to accept the chain dampener but the actual dampeners were not installed in the machined holes. My 02 Z was machined to accept the dampener!!
This is a harmonic balancer. Its the thing that the pipe wrench is attach to:
I have a cam very similar to the G5X4. Lots of lift. The base circle of the cam on aftermarket cams is smaller and that put the lifter oiling hole out of position from where it is normally positioned when you use stock lifters. The caddy lifers are suppose to address that anomaly plus the roller is stronger. Better all around lifter than stock.
Bill, I think I am missing the point on this. Can you explain it further?
To get a cam to properly execute high lift at the correct geometry, the cam base circle is smaller. When you have a small base circle, it puts the lifter further into the lifter bore. The lifters oil hole can be partially blocked when this happens. The caddy lifter is designed to prevent this issue.
The lifter roller wheel is also re-designed to be stronger. Instead of the front and back of the lifter being un shrouded, the entire wheel is shrouded.
New CADDY Racing lifters. Notice the entire wheel is shrouded. The OEM wheel is completely open in the front and back which makes it less strong. With extra lift and extended rpm, a stronger lifter is better in my book.
BC
Its adjustable PUSH ROD not rods, you only need one Basicly, you check for the proper length pushrod and then you measure it and get a full set the length that you measured.
To find the proper length choose a lifter that is all the way down on the base circle of the cam. Then slide your adjustable push rod in place and install a rocker arm. Adjust the push rod so the tip of the rocker arm is in the middle of the valve stem. lock the adjustable pushrod and then cycle the motor to make sure the rocker arm dosent roll of the top of the valve stem. measure the lenth of the pushrod with a caliper and you will have the size you need.
Note: This is how its done on first gen smallblocks which i have done it on before. Not sure if its different for a LS motor so if there are any extra steps im missing please feel free to chime in...anyone and everyone
