Oil pump question.
Have you pulled the valvecovers to check the top of the motor?
I tore it down to this on the first day.
It looks like this now.
- the motor has been painted black
- part of the wiring harness was routed around the motor mount wrong.
- motor leaked oil at the front of the oil pan where they either didn't line up the front cover correctly or they didn't put the dab of silicone in the corners where the block and the front cover meet.
-the pistons look to be brand new, but the car only had 65 miles on it before it went swimming.
- the harmonic balancer looked like they used a big pipe wrench to hold it from turning while the took the bolt off.
Nope, I helped a buddy put an alternator on his daughters car.
I only drove the car about 30 miles with this oil in it. There is more of the fiber stuff in the pick up screen and what looks like some kind of gel.
Close up.
This is what was left in the oil pan after draining the oil.
Rod bearings, piston #7.
Piston #8. They don't look nearly as bad as what the oil pan shows.
I hope the crank is ok. What do you all think?
Somebody please tell me that any of this is normal.
Eric D
Remember, this is my wifes car, so drag racing, high rpms, etc., will not be in it's immediate future.
Something equivalent to stock will be fine.
Eric D
Eric D
The bearings that came out are GM bearings. Are there any markings on them that would tell you if it was an oversize bearing? Does GM even sell "other than stock" bearings?
If you have the crank out of the engine I like to mic it to find the proper shell size to use. I also like to use Plastigage while putting it back together. Plastigage, though not as good as micrometer check will still give you useful information. Here is a link on how to use it: http://www.tpub.com/content/construc...383-24_433.htm
Eric D
I decided that I didn't want to take the motor apart for a third time, so I took some peoples advice and pulled it and tore it down to nothing. I even took the rings off of the pistons. I took the bare block out in the driveway and stuck a garden hose into every orifice on it. It is enema clean now.
Cool story on the crank. I decided I better have someone look at it, but I had no idea who to call in my area. I opened the phone book and saw a listing for Blah, Blah Race Services (I don't remember the real name). I figured they were a good place to start. I called and they said that they outsourced all their crank work. I asked for that name and number. They told me to call Hitch Repair. Now, I'm thinking, I don't need a trailer hitch on my vette.
The owners name is David Hitch in Maryville, TN. When I called, I told him I had a crank that I needed someone to look at. He asked what is came out of. I said it came out of an LS2. He said oh yeah, LS1, LS2, LS6, LS7, we do them all the time. The knowledge of the lingo did make me feel somewhat comfortable. When I got down there, he said that it definitely needed to be turned and then, when we got to talking and he said that he had built 10-12, twin turbo LS7 motors this year, along with many more, less radical LS motors. It turns out that he builds all of Nick Steffens (supporting tuner BLOWNZ06) motors. Needless to say, I was not the least bit worried about the kind of job that was going to be done on my crank anymore.
David did a great job and the crank came back with a mirror finish. He had to go .020 on the crank and .010 on the rods. Everything mic'ed out perfect and it is running like a champ with 60+ psi of oil pressure cold and 35 psi hot, at idle. I have still never figured out what the "hair" is.
Thanks again for everyones help and advice.
