Most Cost Effective LS1 Performance Mods
Old Jul 30, 2008 | 10:17 PM
tb30570's Avatar
tb30570
Default Most Cost Effective LS1 Performance Mods
What are the most cost effective performance mods to get a 345 hp LS1 to about 400 hp? Assume my time to install parts is worth something too, about $50/hr. Also assume I don't have a lot of free time. NOS is not something I would consider.
What mods should be performed to pick up about 50 hp?
-Cold Air Intake?
-Larger Injectors?
-Aftermarket Programmer?
-Ignition Controller?
-High Flow Cats & Mufflers?
-Other Suggestions?
I appreciate your suggestions.
Old Jul 30, 2008 | 10:29 PM
rob-cyn's Avatar
rob-cyn
List looks good, most of the gearheads on the Forum rave on longtube headers, cam and custom tune. Headers are what I aim to get next, as I have a Vararam intake and a Corsa Pace car exhaust.
Old Jul 30, 2008 | 10:36 PM
tb30570's Avatar
tb30570
How much do you think it would cost for headers and exhaust installed? Does the engine need to be pulled to install the headers?
I don't know that there are any locations near me for a custom tune. I'm in the middle of North Dakota. Are Hyperteck, JET or Superchips close to a custom tune?
Old Jul 30, 2008 | 10:55 PM
Dave68's Avatar
Dave68
For about $20/HP, you can get a Cold Air Intake that'll give you about 15 HP (12 or 13 RWHP).
By comparison, a supercharger will cost you about $50/HP (installed) and about $37/HP for a DIY job.
Nitrous may very well be the best bang for the buck, but the risk factor is up there as well.
Old Jul 30, 2008 | 10:57 PM
tb30570's Avatar
tb30570
Sorry for my stupidity...what is a DIY job? Sounds adult.
Old Jul 30, 2008 | 10:58 PM
itzza427's Avatar
itzza427
No you do not have to pull the motor for header install.They just covered header and Hi-flow cats install in the September issue of Corvette Fever (just delivered in the mail a couple of weeks ago). Seems headers run around $1500 + or - a couple hundred (from what I read here on the forum) Don't know much about them and tuners as mine is pretty much stock(I do follow a lot of this stuff here though) I'm sure there will be a lot more jump in soon!!
Old Jul 30, 2008 | 11:02 PM
motogib1's Avatar
motogib1
Are you talkin 400rwhp or 400 hp crank. Either way, Larger Injector, Ignition Controller are not part of the list. I would say long tube headers with high flow cats, a good cam and of course some tuning from a professional tuner could get you there. And of course a true cold air intake such as a vararam or callaway honker can't hurt anything.
Old Jul 30, 2008 | 11:03 PM
tb30570's Avatar
tb30570
Got it...Do It Yourself?
Old Jul 30, 2008 | 11:06 PM
cbug's Avatar
cbug
diy = do it yourself
Old Jul 30, 2008 | 11:13 PM
tb30570's Avatar
tb30570
Crank power. I want the LS1 to be close to the power of an LS6 or LS2.
I assume the engine has to be pulled to install a hotter cam? If so, I'm not sure I want to go down that road.
What kind of costs and power gains would I see for these mods?
-Cold Air Intake - 10hp - $300
-Larger Injectors - not worth it
-Aftermarket Programmer - XX hp - (don't have access to custom tune)
-Ignition Controller - not worth it
-Headers - XX hp - $1500
-High Flow Exhaust - XX hp - $XXXX
-High Flow Cats & Mufflers - XX hp - $XXXX
-Other Suggestions?
Am I better off buying a new LS6 @ $5200?
Old Jul 30, 2008 | 11:14 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
First off, Welcome. Don't forget to wave.
Second, DIY is Do it yourself.
Third, your list.
I think most would say a handheld programmer is not a good investment. I can't say for sure on a Corvette. On my truck it was a total waste of money.
The stock injectors can supply more fuel than an LS1 can use until you either add a large cam or forced injection
My best advise is (in order):
1) more air in,,, cold air intake.
2) more air out,,, headers, hi flow cats, catback exhaust
3) professional tune
Good luck.
One more thing. Don't over-value your time. If you aren't doing the work yourself because you WANT to then pay someone else to do it. Look at it this way. If your time really is worth $50/hr, you go to work and pay someone else $80/hr to work on your car. In the end the difference will be $30/hr (make $50, spend $80). But really, do it yourself if you can. It's great quality time.
Old Jul 30, 2008 | 11:21 PM
tb30570's Avatar
tb30570
has anybody ever heard of a custom tuner in Centeral to Eastern ND, Northern SD or Western MN?
Old Jul 30, 2008 | 11:28 PM
tb30570's Avatar
tb30570
Third, your list.
Good luck.
Do you think the (3) you list will pick up around 50 hp? I wouldn't mind doing the cold air intake and headers DYI. I don't think I want to weld on the exhaust though DYI. I'm not bad welding in position, but out of position is a different story.
Old Jul 8, 2009 | 12:20 AM
tb30570's Avatar
tb30570
I recently finished working on one of my other cars and am ready to start looking at the Vette again.
http://www.redlineforums.com/forums/...-800-a-20.html
I'm going to price out a full exhaust system first. I'm looking for a set of headers, X-pipes, over the axle pipes, mufflers and tips. I'd like 2.5" from the accumulator to the back. I don't plan on running CAT's.
Does anybody sell a complete kit at a better price than buying components? I've looked around and can only find header/x-pipe combos or cat-back systems. I didn't see any complete systems.
Old Jul 8, 2009 | 06:36 AM
AU N EGL's Avatar
AU N EGL
Third, your list.
Good luck.
Best VALUE for your money is to have your car dyno tuned by a competent tuner. that will run $400-$500 but you will get that 50 or so hp you are looking for.
Good Luck
Old Jul 8, 2009 | 08:55 AM
gleds's Avatar
gleds
Good Luck
Sorry, but not possible. Maybe if he bolts on long tubes and cai and then gets a tune.
Old Jul 8, 2009 | 09:30 AM
Patches's Avatar
Patches
Try these diy sites to start.
http://ls1howto.com/
http://97vette.com/
To Most Cost Effective LS1 Performance Mods
Old Jul 8, 2009 | 10:39 AM
travelingypsye's Avatar
travelingypsye
Good Luck
I agree. I gained 40+ lbs of torque & 30+ hp just haveing a dyno tune.
Old Jul 8, 2009 | 11:03 AM
jbondfl's Avatar
jbondfl
Yes, these three will get you over 50hp.
You could actually skip the catback if you wanted. The stock one isn't that restrictive (just quiet).
The firt 50 hp is the cheapest ($/hp). After that is starts to go up quickly.
Old Jul 8, 2009 | 11:12 AM
Drunken Master's Avatar
Drunken Master
"forget the jet"
