ported 90/90
Old Sep 4, 2008 | 05:13 PM
  #41
99C5JA1's Avatar
99C5JA1
That is great info Tony and I really appreciate the response. That's certainly enlightening on the 78mm version. However I'm still fuzzy on how a step up to a 90mm TB and intake would give any sort of a gain with the 75mm MAF in place. You should be utilizing it's maximum airflow in a 78mm setup and stepping up to a 90mm setup wouldn't allow anymore air into the system. It would be stuck at the maximum flow of the MAF.
Old Sep 4, 2008 | 05:30 PM
  #42
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
IMO, it's mainly due to the airflow entering the intake with the different entry size and interior shape allowing more airflow to reach the cylinders (the 90mm design is a little better than the 78 mm version).
Keep in mind you are only actually seeing a small percentage increase in power (1%) in spite of a 40-50% increase in total available airflow (on paper looking at max CFM at the TB) moving from a 75mm TB to a 90mm TB.
And the larger 85mm MAF is only worth a few more ponies (about 3HP) over its smaller 75mm brother. In fact you can eliminate the MAF completely and see a total of 5 HP over the same engine with an 85mm MAF installed as a baseline (at the 600 HP level at the crank....less on a lower output engine). That would indicate the total power loss associated with a 75 mm MAF even at the 600 HP mark is only around 8-10 HP.
Tony
Old Sep 4, 2008 | 05:47 PM
  #43
99C5JA1's Avatar
99C5JA1
Originally Posted by Tony Mamo @ AFR
IMO. it's mainly due to the airflow entering the intake with the different entry size and interior shape allowing more airflow to reach the cylinders (the 90mm design is a little better than the 78 mm version).
Tony
That's the piece I was missing. Makes sense now. Well if you're gaining 5hp moving to the 90, I guess the extra 3hp or so from the MAF can't hurt.
While we're on the subject, any use in a MAF larger than 85mm on an NA 346? My gut says that any gain would be very minimal and not worth the investment. Now on a 400+ cube stroker I would guess very large MAF's should be well worth the time and money.
Old Sep 4, 2008 | 05:54 PM
  #44
0Tony Mamo @ AFR
Former Vendor
Anything over 400 RWHP (which puts the engine close or better than 500 at the crank) will benefit a little from the switch to the larger MAF....and like any other mods some more than others.
BUT...for the price, assuming you were dropping dime on a 92/90 set-up (and especially a ported one looking for all the money), the swap to an 85mm MAF at the same time would certainly help your cause (but require a new tune to compensate for it).
Tony
Old Sep 4, 2008 | 06:00 PM
  #45
99C5JA1's Avatar
99C5JA1
Well you SHOULD be tuning it with the 90/90 setup anyway. Thanks as always for your insight Tony.
Old Sep 4, 2008 | 06:09 PM
  #46
N4cer's Avatar
N4cer
Exactly. The OP says "Ported", but then just shows port matching. BIG difference. Porting the intake is done inside... the ports are just a detail compared to the inner porting. Port matching is a simple job. Porting the interior is where the mastery is needed.
So is this supposed to be "ported"? Or just "port matched"?
Old Sep 4, 2008 | 06:20 PM
  #47
vettenuts's Avatar
vettenuts
Tony posted some photo's several months back that he had sent me when he did my intake. All I can tell you is that the porting work is head and shoulders better than that shown in the first post of this thread. I plan to take advantage of that work next month when my Dart heads come off and the AFR heads go on, that also have some of Tony's handiwork.
Old Sep 4, 2008 | 09:12 PM
  #48
ssmith512's Avatar
ssmith512
Ya, I hear that Mamo fellow has a weird fetish for F.A.S.T. and aluminum shavings/dust! LOL!
Old Sep 5, 2008 | 09:17 AM
  #49
VIPERBLUELX's Avatar
VIPERBLUELX
Tony
If I keep the stock MAF, can I swap from an LS6 intake to Fast 90/90 and keep my same tune for now?
Old Sep 5, 2008 | 11:35 AM
  #50
0Tony Mamo @ AFR
Former Vendor
For the most part yes.....it depends on the 90mm TB and if it was ported or not. Not ported shouldn't be an issue.....if it was ported its hit and miss depending on who did the work and how aggressive they got (you might have hanging idle and things of that nature due to the larger airblade not being compensated in the tune).
I usually recommend to my customers wanting to swap to the larger MAF to simply bring it with them to the shop when its time for the tune (and previous to that making sure you have the right complimenting parts to install it by taking the time to sort all that out prior to going there).
Tony
Old Sep 5, 2008 | 03:19 PM
  #51
VIPERBLUELX
Thanks, i'm not gonna swap my stock ls6 MAF, I think it's what 85mm anyway? And I'm going to run my stock LS2 throttle body, although I might polish it if there's any benefit to that, but no material removal. I can't see the need to port a 90mm throttle body for an n/a 346 car with mild heads and cam, do you?
Old Sep 13, 2008 | 03:25 PM
  #52
sweetc6's Avatar
sweetc6
Please PM me the sponsor name also
Old Sep 13, 2008 | 04:02 PM
  #53
chevy406's Avatar
chevy406
Read the thread. It has already been disclosed, plus you can learn some good information about intake, throttle body and MAF flow.
Old Sep 14, 2008 | 01:39 PM
  #54
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
good thing the guys over on LS1tech havent seen some of the info in this thread
I dont have the heart to cut and paste it
Old Sep 14, 2008 | 01:45 PM
  #55
VIPERBLUELX
the nut swinging moderators over there would delete it if you posted it
Old Sep 14, 2008 | 03:22 PM
  #56
WKMCD's Avatar
WKMCD
And probably ban you...
Old Sep 15, 2008 | 01:06 PM
  #57
SStrokerAce's Avatar
SStrokerAce
Why does anyone think you can port ANY manifold without the heads it's being attached to there as well?
To ported 90/90
Old Sep 15, 2008 | 03:22 PM
  #58
0Tony Mamo @ AFR
Former Vendor
Well I obviously can't speak for anyone else, but concerning my personal situation, if we are discussing an intake that's ultimately bolting up to one of our CNC 205 or 225 offerings, every port entry is the same and at this point I could port match a FAST to either of those two heads in my sleep.
I also have the luxury of seeing alot of my competitors CNC product so that is very helpful as well concerning port size and location (most are actually very similar). The only real issues is porting intakes for hand ported heads (or stock heads) when there can be a big disparity in port width, height etc. and in the event I am porting an intake for someone in that situation I usually have them provide me with measurements so I have a better idea of how aggressive to get on the port exit of the FAST. The reality is most of the gains that actually help airflow are up the port aways and the actual exit size doesn't have to big a role on airflow assuming it's at least close....
Tony
Old Sep 15, 2008 | 08:21 PM
  #59
SStrokerAce
Tony, I understand if you have the heads there like your AFR's, otherwise I don't think it's prudent to sell or buy one.
Old Sep 15, 2008 | 09:18 PM
  #60
N4cer's Avatar
N4cer
Once again, it becomes brutally apparent that some people lack understanding that "porting" an intake is internal in the runners, and "port matching" is the ends of the runners matching the heads. This thread is about "ported" intakes. Not "port matched". My dog could port match an intake. But doing the porting (in the runners) is much tougher.
