2002 just died
Old Jan 6, 2002 | 02:07 AM
Joel Fromkin's Avatar
Joel Fromkin
Default Update on 2002 just died
I went to the local 7-11 with my daughter at midnight,came out and the car is DEAD!!! WTF? The battery has full power. Turn the key and you hear one click and thats it. A couple of guys pushed me to try to "bump" start it and when I popped the clutch the wheels were locked. I feels like the engine is siezed. The car ran great on the way there no noises or anything else. Has this ever happened to anyone else? :confused: :eek: :confused: :eek: :confused: :eek: :seeya
[Modified by Joel Fromkin, 3:02 PM 1/7/2002]
Old Jan 6, 2002 | 02:09 AM
99 Corvette's Avatar
99 Corvette
Default Re: 2002 just died (Joel Fromkin)
Never happened to me but I have to say that is one beautiful Corvette :cheers:
Jerry
Old Jan 6, 2002 | 02:12 AM
Lashtal's Avatar
Lashtal
Where you driving in the Rain or heavy snow?
Any codes come up?
Check the fuses. If nothing there, then I would check the filter (see if it is wet), take a plug out and check its condition, check the battery charge.
:cheers:
Old Jan 6, 2002 | 02:25 AM
molon labe's Avatar
molon labe
sounds like a loose wire, or fuses. check all relevant wiring under the hood.
Old Jan 6, 2002 | 02:39 AM
Joel Fromkin
Default Re: 2002 just died (Lashtal)
Thanks,I'll check the wires in the morning (it's 1:31 am now). What really has me concerned is that when i popped the clutch the wheels were locked. Usually they "hop" a little. Their has been no snow or rain on this car, however, I spent three hours washing it today, then put it in the garage, then drove it about 1/2 mile to 7-11. Oh well...it always gets dirty at the dealer so that three hours was a waste. I'll keep you posted...Thanks again :seeya :seeya :cheers:
Old Jan 6, 2002 | 03:12 AM
The Batman's Avatar
The Batman
About once every two years, my 1994 Z-28 does the same or less. Turn the ignition, then it clicks or does nothing. Lights and radio still work, starter just won't turn it over. I leave it for 10 to 20 minutes, come back, and it roars back to life, no problem. I don't get a jump, I don't disconnect and reconnect anything, the most I do is open the hood and check the connections.
Obviously, something electrical, but I can't repeat the problem. I've still got the original starting system, and it works over 99% of the time. My uneducated guess is the starter solenoid somehow hasn't stored enough amperage. I don't know why. Please share if you find any info on this gremlin.
Old Jan 6, 2002 | 03:31 AM
MilYellow02's Avatar
MilYellow02
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Sorry to hear your bad luck....I also had gremlins in my car for about 5 minutes....Good luck and let us know in the a.m. :seeya
Old Jan 6, 2002 | 05:32 AM
KZ1000's Avatar
KZ1000
I can't help you with your problem, but I must comment on those pic's of your beautiful car :)
KZ
Old Jan 6, 2002 | 06:03 AM
Ilhan's Avatar
Ilhan
Dont ever try to BUMP Start a car whit cats because you will destroy them. :nono:
Old Jan 6, 2002 | 08:42 AM
vettenuts's Avatar
vettenuts
Default Re: 2002 just died (Ilhan)
Did you push start in 1st gear? I usually use second gear as with many light high compression cars the wheels can't turn the motor over. Good luck with your problem, I would like to see what it turns out to be. I just got an 02 myself.
Old Jan 6, 2002 | 10:33 AM
geekracer's Avatar
geekracer
How did you get it home? Any messages on the DIC when it happened?
Old Jan 6, 2002 | 01:15 PM
CliffB-99's Avatar
CliffB-99
MagRedMonster's starter went out on his C5. Maybe the starter?
Old Jan 7, 2002 | 05:01 PM
Joel Fromkin
Default Re:Update on 2002 just died (Joel Fromkin)
O.K....Just got the call from the dealer. At first he was worried because the engine wouldn't even turn over by hand. Turns out that the starter came apart on the inside. He will have one tomorrow morning and I can pick up my car tomorrow nite. :yesnod: :yesnod: :seeya :seeya
Old Jan 7, 2002 | 05:28 PM
GR8-LIFE's Avatar
GR8-LIFE
Default Re: Re:Update on 2002 just died (Joel Fromkin)
WOW!!! That was a close one!!! I would have been scared of the NOS.
Old Jan 7, 2002 | 05:34 PM
jawski's Avatar
jawski
Never heard THAT one before :confused:
Old Jan 7, 2002 | 11:58 PM
vettedevil's Avatar
vettedevil
Default Re: Re:Update on 2002 just died (Ha-Ha)
all right, all fixed, life is good! Now can we do 160 side by side again? that was fun!
[Modified by C5Coup, 12:04 PM 1/9/2002]
Old Jan 8, 2002 | 12:06 AM
Dave68's Avatar
Dave68
That happened to me one day back in 1980 in my 68 Cougar. It turned out that a roller bearing got jammed inbetween the flywheel and the starter bendix gear. The tow truck driver thought the engine had seized, so he offered me $50 for the car. I knew that you generally don't go from a smooth-running V-8 to a seized-up motor without hearing any noise inbetween.
The big question was - Where did that roller bearing come from?
Congratulations on your huge sigh of relief! :cheers:
Old Jan 8, 2002 | 12:42 AM
Joel Fromkin
Default Re: Re:Update on 2002 just died (C5Coup)
C5coup...yes that was fun...especially all 4 of us blasting by the state trooper at 160 plus!!!! :cheers: :cheers: :lol: :lol: :lol:
To 2002 just died
