Ignition Switch Problem?
Old Sep 29, 2008 | 08:02 PM
bassman12350's Avatar
bassman12350
Default Ignition Switch Problem?
I hope I'm not duplicating a thread. I searched exhaustively for this issue, but was not able to find information regarding my specific problem.
My '04 (28,000 miles) starts and runs fine when cold. It also runs fine when warm and hot. However, on warm restarts, the engine will turn over properly and start, but then die immediately. This happens anywhere from two to four times. Sometimes, depressing the accelerator to the floor and immediately releasing it prior to starting does the trick. After the problematic start, it runs flawlessly and with full power. I don't seem to have any other issues related to an ignition switch problem, or any other problem for that matter.
Any thoughts? Thank you!
Old Sep 29, 2008 | 08:09 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Have you pulled the codes yet?
Old Sep 29, 2008 | 10:28 PM
bassman12350
Nope. Was going to do that after supper. Thanks for the reminder!
Old Sep 29, 2008 | 11:45 PM
bassman12350
There were only two codes listed:
1). 60-IPC: B0516H
2). 99-HVAC: B0367H
No other codes were list for either these or any other modules.
Thanks.
Old Sep 30, 2008 | 05:27 PM
bassman12350
Cleared all the codes today and tried again. Got a repeat on the problem after driving a short distance. Took 4 tries to get the engine to continue running after attempting to start it. Only one code posted:
99-HVAC B0367H.
No other codes were thrown after the failed start-run sequence. Car still runs flawlessly once I can keep it running.
Old Sep 30, 2008 | 08:03 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
1). 60-IPC: B0516H
2). 99-HVAC: B0367H
Thanks.
first code is speedometer signal circuit malfunction
second code is right actuator feedback open
My car is doing a similar thing and just tonite it shut off while driving for the first time. Had just been a startup problem, fuel pump not running after car starts and not running prestart cylce.
Car will stay running if I hold the key in the crank position.
I changed out the ignition switch,,,,,no deal.
cleaned a few ground location I could get to,,,,no deal
tonite the car started and ran strong so I took her for a spin. While cruising down the highway she died. I got her restarted and got her home.
I pulled the codes and are as follows:
60-IBC B0521H - Tachometer signal circuit malfunction
first time for this one tonite
BO-RFA U1096H - Lost communication with XXX
BO-RFA U1064H - Lost communication with XXX
BO-RFA U1016H - Lost communication with XXX
10-PCM P1571H - Traction control torque request circuit
I am at wits end as I am sure you are too!
Do you get gauge and dash lite function when it dies? I did until tonite
Old Sep 30, 2008 | 08:10 PM
bassman12350
I'm not having problems with the dash or gauge lights. I do have a weird problem with my "Driver Memory options" in that the "memory" seems to get lost if the car sits overnight, or for a long time during the day. Also the AM radio (on distant stations) is very scratchy and pops/scratches more going over bumps. I'm beginning to think I've got some bad grounds.
If you haven't had problems with the codes you have getting thrown before, I'd suspect you've got a ground that went out on you somewhere. My speedom. code cleared and hasn't returned, but the HVAC one did. Funny thing is, I'm having no problems with my climate control.
Old Sep 30, 2008 | 08:15 PM
Silverbullet00
I agree, I think is a ground prob!
Check your pm's in a minute for my phone number,,,,I would like to compare notes
Old Sep 30, 2008 | 11:29 PM
bassman12350
Kent,
PM'd you and tried you phone # about 5 ago. Am awaiting your call.
Old Oct 1, 2008 | 09:59 PM
bassman12350
......I agree, I think is a ground prob........
Kent,
Check two things:
1). There is a large ground connector to the left side (front) of the block on the left frame rail. The connector is designed as an integral socket and plug with four (?) wires going into it. Unplug and then re-insert the plug into the connector. Even if the terminal ring is tightly bolted to the frame rail, if the connector contacts are oxidized, it could cause the problem.
2). Unplug and then re-install the IGN relay (#42) in the main fuse block. I think it might stick sometimes.
I just played around with those two "obvious" things, bending the wires and jiggling them as they enter the ground connector and the unplugging/plugging in the IGN relay. It clicked when I removed it (key off, battery connected), but did nothing when I plugged it back in.
I have not had problem one today, whatsoever. This is with probably 8 - 10 warm/hot restarts (ran a lot of errands today). Car ran flawlessly. When I work on mine, I am going to pull every ground connector plug and clean the contacts. This is on top of cleaning each ground contact where they mate to the frame.
Hope this is it and it works for you!
Old Oct 1, 2008 | 11:34 PM
bestvettever's Avatar
bestvettever
Default Start and Run Problem
Hi, Problems such as bassman's and silverbullet's are often from the grounds or connections being loose or corroded. But don't take for granted the battery and cables. It's a good idea to load test the battery, and make sure both cables are clean and tight to the battery, starter lug,(often the starter lug proves to be loose or corroded), the ground, and the underhood fuse block. If they check out then check all the ground locations.
Good Luck
SEE BELOW
Old Oct 2, 2008 | 12:16 AM
bassman12350
Good Luck
Thanks for the suggestions. Gonna do the ground connection check thing throughout the whole car when I get time. Hopefully, she'll keep running until then .
Old Oct 2, 2008 | 12:25 AM
Silverbullet00
Putting mine on the ramps tomorrow and checking all grounds and connections!
Bassman, did you burn your app yet?
Old Oct 2, 2008 | 12:39 AM
bassman12350
But of course, Kent! Made it into a Word document so I can forward a copy to the Motherlode Corvette Club (also a non-club) for perusal.....
Thanks again. It's just too cool!
Old Oct 2, 2008 | 11:29 PM
Silverbullet00
Ramps didn't work! Dead vette for sale to ingnorant fool,,,,,NOT!
Old Oct 2, 2008 | 11:42 PM
bassman12350
Kent,
Did you get the Rhino Ramps or another pair and the Vette didn't fit on them, or did they not raise the car up enough? Gotta know - - getting ready to buy a pair.
Old Oct 2, 2008 | 11:57 PM
Silverbullet00
Kent,
The one's a vette buddy brought by tonite, rino ramps, would not allow my car to clear enogh to pull up on them!
To Ignition Switch Problem?
Old Oct 3, 2008 | 12:38 AM
bassman12350
I've heard these might not be angled "shallowly" enough to allow the C5s to go onto them.........HMMMMMM. Park over a curb?
Old Oct 4, 2008 | 12:03 AM
bestvettever
Default Ramps no work
Hi use a couple of 4ft 2X12 wood planks before the ramps. Make a step with one on top of the other if neccessary. Secure them to the ramps
Good luck
Old Oct 4, 2008 | 12:05 AM
Silverbullet00
Well I called in the Air Force and they came through, three fellow non club clubber's, one of whom is a jet tech talked with yet another non club club on the phone after we eliminated several more grounds and the starter connections as the problem. He pulled the fuel pump relay and jumped it, fuel pump came on and stayed on car ran great enough for 13.3 1/4 mile tonite at 108 mph. The PCM is due to be replaced Monday. Hopefully problem soon to be solved!
