cam install
Old Oct 6, 2008 | 11:25 PM
run and gun's Avatar
run and gun
Default cam install
installing blower cam, what is the best oil pump and timing chain to go with while i am in there. thanks jim.
Old Oct 7, 2008 | 05:45 AM
vettenuts's Avatar
vettenuts
Katech has a blueprinted and ported LS6 oil pump. I would also go with the Katech timing chain if you are not degreeing the cam, Cloyes if you are.
Old Oct 7, 2008 | 08:17 PM
run and gun
Default cam
thanks man. jim
Old Oct 7, 2008 | 08:31 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I went with a GM LS4 oil pump which is a high volume pump and a LS2 chain which was noticably beefier than the LS6 chain I took out.
Old Oct 8, 2008 | 08:13 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
same here. If you do go with the LS2 timing chain, you may have to clearance the timing cover a little. Also when putting on a LS2 timing chain, there is a wrong way to put the spacers on. Make sure they properly line up with the oil pump or you'll be tearing back into it to fix your oil pressure issue.
Old Oct 8, 2008 | 10:21 AM
Cobra4B's Avatar
Cobra4B
^ Spacers? I had no issues with anything like that. Mine all bolted right up w/o needing to shim or clearance anything.
Old Oct 13, 2008 | 08:21 PM
Katech_Zach's Avatar
Katech_Zach
Premium Supporting Vendor
C7 of Year Finalist (track prepared) 2019
You can use the C5-R chain with the Cloyes gears if you want.
__________________
Contact:
(e) zach@katechengines.com
Old Oct 13, 2008 | 08:32 PM
pdd000's Avatar
pdd000
I went with a dual roller
To cam install
